3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Led Candles Moodlight
Here is a simple way to make a "led candles moodlight".
You'll have a slow color changing candles group to enlight your living room during Christmas holidays.
Step 1Parts and materials
Parts and materials
You need these parts and materials:
- slow flash color leds (browse ebay with these keywords), I used 3 of 5mm type
- moderately large votive candles, 3 as above, 6cm or higher and 6cm in diameter
- a base platter (wood, ceramic, metal ... I used a square piece of plywood, just too small, damn ... a plain porcelain dish would works great)
- a wall wart power supply (I used a 12V/100mA one, but every type from 5V upto 15V works)
- a female connector that match the power supply output connector (barrel, jack etc)
- a 5V/1A regulator IC(classic 7805 or so)
- a 100uF/16V electrolytic capacitor
- some insulated copper wires (short pieces from net cables work well)
- electrical tape or heat shrinking tube (2-3 mm type)
32 comments
Nov 14, 2010. 9:59 AMjadedjas says:
I LOVE Selenite! It's just beautiful when you mix it with any kind of light!
Dec 12, 2009. 2:14 PMaltontoth says:
More like recommended, not required.  You could get away with NOT using it, and 99 times in 100, your projects will operate perfectly fie.  They throw the capacitor in there for that 1 time that the project is sensitive enough that everything freaks out without it.
Jul 2, 2009. 10:38 PMmeissler says:
What's the point of using a capacitor here? What would happen without it? I know a capacitor stores charge, but I can't see why it's needed. Thanks!
Feb 12, 2009. 3:49 PMburndin says:
Instead of using candles I used a stone called Selentie. It came out very well.
Feb 12, 2009. 3:50 PMburndin says:
Selenite*
Jan 4, 2009. 12:58 AMnoelle_tan says:
wait so it's actually made of wax? I thought they were plastic cases
Dec 17, 2008. 4:26 PMdirkovic2112 says:
Cool project. I think my sister will love this!
Dec 8, 2008. 1:21 PMjafrance says:
In an attempt to recreate this project as true to the instructions as possible, I have ordered everything as is listed on the parts list. The missing piece is now the power supply. I am having a hard time finding the 12v/100mA supplies anywhere for what I consider a reasonable price. Can anyone help? I would also like to enclose the regulator and capacitor for a cleaner looking gift. What would you use?
Dec 9, 2008. 3:02 PMjafrance says:
Thanks for the reply! I happened to find 3 of the power supplies with the same specs that you used. My next question is, how does one know what barrel to use? Is there anything inparticular that I need to know on that front? Also, I have bought almost everything for this project from Digi-Key, but cant find barrel's though them. Any suggestions?
Dec 9, 2008. 8:40 PMjafrance says:
Thanks again for your insight.
Dec 6, 2008. 6:52 PMCyberA says:
Great Project! I thought I would make one for my mother for this Christmas. Had some parts and got some and the cost was no more than 10$. Dollarama is a great place for items (rocks, wood tray…). I use a low voltage and did not require the regulator and added a switch to turn on and off. Here are a few shots. Thinking of making myself one ;) Thanks!
Dec 2, 2008. 4:01 PMAntipassifist22 says:
This is an awesome project, just to put it out there. I really wanted to do this so i got the LEDs and all the other electrical items but i ran into a slight problem and i hope that someone could help me with this: Whenever i start up my LEDs, they all start at red, then move all to green, then all blue, then all green, then all purple, so forth and so on, but i was wondering if there was a way to make the colors different from each other seen in the video above or am i pretty much going to have to live with what i got now.
Nov 29, 2008. 6:44 PMCybergeek004 says:
On ebay I only see RBG color LED's does that mean they will also fade to purple or pink ect. ect. colors? I have some at home that only do red blue and green (RBG) or is that a different type of an LED?
Nov 27, 2008. 8:37 PMagis68 says:
Nice instructable. I will try it soon...
Nov 22, 2008. 5:54 AMscribbler says:
beautiful instructable. Am thinking of breaking the mould (pun intended) after I finish making the basic model with a few other designs... will update.
Nov 20, 2008. 12:56 PMlolong says:
hey! how to change the colours? because the circuit is:
Source 5V --> capacitor -- red ---- green --- blue
| led led led
the source is a continous voltage...
Nov 20, 2008. 7:02 PMShadowGirl says:
Yours are much nicer than the dinky one-color imitation led candles the stores are selling for the winter holidays.
Nov 17, 2008. 12:27 PMfwjs28 says:
you mean holidays
Nov 18, 2008. 11:24 AMfwjs28 says:
np...you do know that if you use Firefox it has a built in spell checker....
Nov 16, 2008. 8:56 PMThe Expert Noob says:
hmm.... I have some 3v amber colored LEDs. I could make a "candle flicker" circuit that is powered by a button cell and set it down inside of a candle that has a burned out cavity.
Nov 17, 2008. 12:28 PMcomodore says:
Hahaha, I was just working on something like this! I made mine whit film canisters and some hot glue to sculpture the flame, ofcourse I used LEDs and i even trough in a joule thief... nice project! rate:***** +added to my mythbusters group
Nov 16, 2008. 6:43 PMChrysN says:
Beautiful, those really glow and no dripping wax and flames do deal with, nice instructable
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:amaze1
