Step 3Assemble the power supply
Female connector, voltage regulator and the electrolytic capacitor are assembled together with the only support of the wood baseplate. I used a small self-threading screw on the regulator hole to secure all.
It may seems hazardous, but regulator is largely oversized (3 leds sink about 60mA and regulator handle 1A) , have internal short circuit and termal overload protections, so it can't ignite the wood baseplate. An heat sink may be used for more safety, also an U shaped aluminium foil piece can works, pay attention to avoid terminal shorting and metal pad itself is connected to the ground terminal.
Anyway keep it away from curtain or so and (standard disclaimer) "I decline any responsibility about your use of this device and damages and other effects that can derive from it. You are responsible of your own actions".
About the leads, facing the regulator they (hanging down) are from left to right: IN - GND - OUT .
Picture made with FidoCAD http://www.enetsystems.com/~lorenzo/fidocad.asp
PS: I found some standard cellphone charger work well to power this circuit without the voltage regulator, just substitute it with a 1N4007 diode.
comments
Add Comment
Add Comment
