Led Chaser With ONLY ONE ARDUINO PIN
253
6
4
Posted
Introduction: Led Chaser With ONLY ONE ARDUINO PIN
A led chaser with only one pin. 3 pins, to bee exact, including all ground and Vcc connections.
Step 1: Collect Your Components
4017 IC
Arduino
10 LEDs
220 ohm resistor
wires
breadboard
Step 2: Connections
Pin 14 of 4017 to Pin 13 of Arduino
Pin 8 to GND
Pin 16 to 5V
Pin 3 of 4017 to positive of LED1
Pin 2 of 4017 to positive of LED2
Pin 4 of 4017 to positive of LED3
Pin 7 of 4017 to positive of LED4
Pin 10 of 4017 to positive of LED5
Pin 1 of 4017 to positive of LED6
Pin 5 of 4017 to positive of LED7
Pin 6 of 4017 to positive of LED8
Pin 9 of 4017 to positive of LED9
Pin 11 of 4017 to positive of LED10
Negatives of LEDs to GND via 220 ohm resistor
Pin 5 of 4017 to pin 8 of 4017
Pin 13 of 4017 to pin 8 of 4017
Step 3: Code
//Copy and paste this code to Arduino.
void setup() {
// put your setup code here, to run once:
pinMode(13, OUTPUT);
void loop() { // put your main code here, to run repeatedly:
digitalWrite(13, HIGH);
delay(100);
digitalWrite(13, LOW);
delay(100);
Step 4: DONE!!!
Led chaser with only one pin.
Step 5: Troubleshooting
LEDs inserted backwards: Reverse the leads.
IC inserted backwards: Pull it out and reverse the leads.
Faulty connections: Press everything in the breadboard. If that didn`t work, look for wiring mistakes.
Code not uploaded: Upload the code to Arduino.
Step 6: How It Works
the arduino gives a clock signal to the 4017. every time the 4017 is energized and deenergized, the 4017 turns the first output off and the sec0nd one on. then the arduino gives a second clock signal and the 4017 turns the second output off and the th1rd one on. this happens to till the 10th output is one and then the 4017 goes back to the 1st output. a 555 timer can also be used to make the clock signal.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
4 Comments
TRY CHANGING THE NUMBER IN THE delay() FUNCTION IN THE CODE TO MAKE THE CHASER GO FAAaaaaaaaaster
LOLOLOOLOLOLO,OLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOLOOOLOOLOOOLLOOLOOLLO
HAHAHAHHAHAHAHAHAHAHHAHAHAAHHHAHAHHAHAHAHAHAHHAHAHAHAHAHHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHHA
The 4017 ic is really static sensitive. Use caution when using it.
Thanks for sharing :)
