Step 10Power supply considerations
To calculate the current draw of your LEDs, connect a led to a 5V power supply with the resistor you intend to use, and measure the current in mA. Multiply this number by 64, and you have the power requirements for the cube itself. Add to that 15-20 mA for the AVR and a couple of mA for each latch IC.
Our first attempt at a power supply was to use a step-down voltage regulator, LM7805, with a 12V wall wart. At over 500mA and 12V input, this chip became extremely hot, and wasn't able to supply the desired current.
We later removed this chip, and soldered a wire from the input to the output pin where the chip used to be.
We now use a regulated computer power supply to get a stable high current 5V supply.
![Hard Wired LED Cube: [No Programming]](http://img.instructables.com/files/deriv/FTD/SF1T/GO8DC8KW/FTDSF1TGO8DC8KW.SQUARE.jpg)
http://www.amazon.com/dp/B00509MOSC/ref=asc_df_B00509MOSC1877744?smid=A1XKPQQA6BPGCN&tag=nextagusmp0357683-20&linkCode=asn&creative=395105&creativeASIN=B00509MOSC
Thank in advance.
I used a 5v psp adaptor, which actually outputs 5.4V but that's okay because the atmega I am using is rated for a maximum of 5.6 Volts.
Good luck!
Thanks,
bl
I do advice you to check the voltage with a multimeter, because sometimes the voltage is much higher than it should be. The voltage would decrease when you put more load on it.
If you would want to use it as a permanent power supply you could just cut of the connector and use the two wires, or you could consider putting a female power plug on your pcb.
Good luck!
Thanks.
Lee
Anyway, it worked fine. No visible dimming even at all lights lit.
What if we use a pass transistor with the 7805?
http://www.primelec.com/ite-5v-1a-power-supply-pc-accessories-power-supplies-p5285586?___store=default
