Step 15Choose the size of your cube
We figured that the easiest way to build a led cube would be to bend the legs of the LEDs so that the legs become the scaffolding that holds the LEDs in place.
We bent the cathode leg on one of the LEDs and measured it to be 26 mm from the center of the LED. By choosing a LED spacing of 25mm, there would be a 1mm overlap for soldering. (1 inch = 25.4mm)
With a small 3mm LED 25mm between each led gave us plenty of open space inside the cube. Seeing all the way through to the furthest layer wouldn't be a problem. We could have made the cube smaller, but then we would have to cut every single leg, and visibility into the cube would be compromised.
Our recommendation is to use the maximum spacing that your LED can allow. Add 1mm margin for soldering.
6
comments
Add Comment
xsuper
says:
Add Comment
![Hard Wired LED Cube: [No Programming]](http://img.instructables.com/files/deriv/FTD/SF1T/GO8DC8KW/FTDSF1TGO8DC8KW.SQUARE.jpg)
