Step 16How to make straight wire
Our first attempt at this failed horribly. We tried to bend it into a straight wire, but no matter how much we bent, it just wasn't straight enough.
Then we remembered an episode of "How it's made" from the Discovery Channel. The episode was about how they make steel wire. They start out with a spool of really thick wire, then they pull it through smaller and smaller holes. We remembered that the wire was totally straight and symmetrical after being pulled like that.
So we figured we should give pulling a try, and it worked! 100% straight metal wire from a spool!
Here is how you do it.
- cut of the length of wire you need from the spool, plus an inch or two.
- Remove the insulation, if any.
- Get a firm grip of each end of the wire with two pairs of pliers
- Pull hard!
- You will feel the wire stretch a little bit.
If you have a vice, you can secure one end in the vice and use one pair of pliers. This would probably be a lot easier, but we don't own a vice.
![Hard Wired LED Cube: [No Programming]](http://img.instructables.com/files/deriv/FTD/SF1T/GO8DC8KW/FTDSF1TGO8DC8KW.SQUARE.jpg)
A good idea is to take soldering steel rods 1mm
They are copperplated,straight and cheap
I pay 3€ for 70pc[ of 1m
Are you referring to steel welding rods? Thanks.
John
this made a very strong and light steel support
