3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Cube 8x8x8
Step 18Build the cube: create a jig
In order to make a nice looking LED cube, it is important that it is completely symmetrical, that the space between each LED is identical, and that each LED points the same way. The easiest way to accomplish this is to create a temporary soldering jig/template.
1)
Find a piece of wood or plastic that is larger than the size of your cube.
2)
Find a drill bit that makes a hole that fits a LED snugly in place. You don't want it to be to tight, as that would make it difficult to remove the soldered layer from the jig without bending it. If the holes are too big, some of the LEDs might come out crooked.
3)
Use a ruler and an angle iron to draw up a grid of 8 by 8 lines intersecting at 64 points, using the LED spacing determined in a previous step.
4)
Use a sharp pointy object to make indentions at each intersection. These indentions will prevent the drill from sliding sideways when you start drilling.
5)
Drill out all the holes.
6)
Take an LED and try every hole for size. If the hole is too snug, carefully drill it again until the LED fits snugly and can be pulled out without much resistance.
7)
Somewhere near the middle of one of the sides, draw a small mark or arrow. A steel wire will be soldered in here in every layer to give the cube some extra stiffening.
7 comments
Jan 22, 2012. 8:11 AMwootner says:
Handy online grid creator (No software to install)
http://incompetech.com/graphpaper/lite/
Nov 7, 2011. 11:49 AMgeckomage says:
i wish i had my own CNC mill. a class im in till the end of the year has a large 5'x12' 3 axis cnc mill (can do aluminum but doesnt quite have enough umph to do steel :[ ) a smaller 2'x3' 4 axis cnc mill. and then a cnc plasma cutter. which is always nice for making robot parts. thanks for the cheaper solution kjet xD i dont have 200,000 to fork out for onna them big cnc mills :P but tech notes, for everyone that has the convienance of a CNC mill, your pointers will surely save time! :D
Aug 7, 2011. 5:22 PMTechNotes says:
Hey guys I finished my milling and I wanted to point out 2 very big mistakes for milling if anyone else is going to do this. The first mistake was that I didn't drill all the way through the board. Pretty obvious, but very essential because when I was done with the layers i was going to solder them together and flip it upside down so the leads are going through the holes. Second big mistake: As you can see, the left milling has drill traces between the holes. I thought it would be a good idea, but it prevents the LED's from fully going in the holes and they pop out really easily.
Aug 7, 2011. 5:23 PMTechNotes says:
Sorry for the small picture, hope you can make use of it with the size that it is.
May 17, 2011. 4:12 AMkjetilhansen says:
A tip that i used when i made mine.. Insted of the angle iron i made a drawing in autocad (can use other also) and made a grid of 8x8 lines, printed it out, and put the drawing on top of the wooden piece and then use a sharp object and punch trough the x'es...
Jul 31, 2011. 2:05 PMTechNotes says:
What I am doing is making an autocad drawing and using a cnc machine to mill it
Jul 31, 2011. 3:08 PMkjetilhansen says:
For those of us that don't have a cnc mill, a normal desktop printer and a 3mm drill bit will be the cheapest :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
651
Author:chr
I like microcontrollers and LEDs :D
