3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Cube 8x8x8
Step 20Build the cube: test the LEDs
We got our LEDs from eBay, really cheap!
We tested some of the LED before we started soldering, and randomly stumbled on a LED that was a lot dimmer than the rest. So we decided to test every LED before using it. We found a couple of dead LEDs and some that were dimmer than the rest.
It would be very bad to have a dim LED inside your finished LED cube, so spend the time to test the LEDs before soldering! This might be less of a problem if you are using LEDs that are more expensive, but we found it worth while to test our LEDs.
Get out your breadboard, connect a power supply and a resistor, then pop the LEDs in one at a time. You might also want to have another LED with its own resistor permanently on the breadboard while testing. This makes it easier to spot differences in brightness.
2 comments
Jan 3, 2012. 11:58 AMnpignatelli says:
Which resistor value should I test the LEDs with?
And which mA value should I expect to see on my multimeter?
thank you.
Jan 15, 2011. 9:42 PMtxrx says:
Another easy way to test if an LED is working, is to use a coin cell battery (aka watch battery). Stick the coin cell between the legs of the LED and then squeeze the legs. You dont need a resistor since the coin cell runs at 3.0 volts and you are only touching it for couple seconds.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
651
Author:chr
I like microcontrollers and LEDs :D
