Step 30Build the controller: layout
Choosing two separate boards was a good decision. The latch array took up almost all the space of the circuit board. There wouldn't have been much space for the micro controller and other parts.
You may not have the exact same circuit boards as we do, or may want to arrange your components in a different way. Try to place all the components on your circuit board to see which layout best fits your circuit board.
![Hard Wired LED Cube: [No Programming]](http://img.instructables.com/files/deriv/FTD/SF1T/GO8DC8KW/FTDSF1TGO8DC8KW.SQUARE.jpg)
It are two printed circuits, 10 x 8cm, stackable, real neat.
Rick
martin31c@yahoo.com
However i also can not download or open the files please could you send me them
martindeakin25@hotmail.com
saintamen@gmail.com
Most files you download get a .tmp extension, you should change this to the correct extension which is displayed on the website where you download the file.
Hope this helps!
next right click the link to the first .sch file
click 'download as'
you can now select the location where you would like to save the file
the filename will be something like FAUI50KGICYB6CJ.tmp as default
change this to the filename that the file should be. for the first file this is multiplexer_board.sch and for the second avr_board.sch
be sure the filename ends with .sch and not .tmp !!!
now open the eagle program
click file->open->schematic and choose one of the files you downloaded.
Hope this helps, I do not know how to explain this any clearer.
Good luck!!!
Please, let INSTRUCtABLES know if and when you solve any problem.
as for the 64 resistors next to the 8 IC's their value is dependent on the type of led you choose in your construction
use the formula source voltage (5v) - forward voltage (3v) / forward current (0.02A) = (100 ohms)
the values in brackets are from my leds just substitute them with the values from your led's when you purchase them
thanks for the information with the resistors next to the transistors
-or-
is it a sort of 'abbreviation' that has each pin from the ribbon header correspond to the representative pin on the register? In this case pin 14 would correspond to 1D and pin 6 to OC.
Thanks
Thanks!
Thanks! ^^
