3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Cube 8x8x8
Step 4What is a LED cube
What is a LED cube
A LED cube is like a LED screen, but it is special in that it has a third dimension, making it 3D. Think of it as many transparent low resolution displays. In normal displays it is normal to try to stack the pixels as close as possible in order to make it look better, but in a cube one must be able to see trough it, and more spacing between the pixels (actually it's voxels since it is in 3d) is needed. The spacing is a trade-off between how easy the layers behind it is seen, and voxel fidelity.
Since it is a lot more work making a LED cube than a LED display, they are usually low resolution. A LED display of 8x8 pixels is only 64 LEDs, but a LED cube in 8x8x8 is 512 LEDs, an order of magnitude harder to make! This is the reason LED cubes are only made in low resolution.
A LED cube does not have to be symetrical, it is possible to make a 7x8x9, or even oddly shaped ones.
3 comments
Mar 24, 2011. 3:58 PMCharlie13 says:
Just wondering, are these safe to have around children? I would like to build one but i'm afraid there would be open circuits for my brother to touch. I'm afraid massive amounts of electrical tape would ruin the effect
Mar 28, 2011. 6:16 PMmartyvonx says:
The voltages are so low that touching the wires poses no danger. (5 volts with current limiting resistors) I'd be more worried about the kids breaking it.
Mar 27, 2011. 3:24 PMaroberts-1 says:
you could put it in a plexi glass case of some sorts to be on the safe side
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
651
Author:chr
I like microcontrollers and LEDs :D
