Introduction: Led Light Bar
This instructable will teach you how to make a LED light bar to use at home for cool effects!! Let's get started!
DISCLAIMER- DO NOT MAKE THIS PROJECT IF YOU HAVE PHOTOSENSITIVE EPILEPSY.
Step 1: Parts
All of these parts could easily be found on amazon or even Maplins if you are willing to spend a lot on relatively cheep components!
- 24 Super bright white 12000mcd 5mm LEDs
- 1 Arduino
- 5mm drill bit
- drill
- saw
- wood. A piece 60 cm long is about right although you can go larger or smaller. It doesn't matter how wide it is.
- wire
- solder and soldering iron
- saw
- hot glue and got glue gun
Step 2: Cut the Wood
Now you are going to want to cut your piece if wood to length. 60mm long is best and the width does not matter. Preferably smaller.
Step 3: Drill the 5mm Holes for the LEDs
Now you are going to want to roughly drill 6 sets of 4 holes all along your wood.
Step 4: Hot Glue Your LEDs Into Place in There Holes in the Wood
Step 5: Solder All of the LEDs Negative Leads Together to Create One Ground for All of the LEDs
Now you are going to want to solder all of the LEDs negative (-) leads together to make one ground wire for all of the LEDs.
Step 6: Positive Connections
Now solder one wire to every set of 4 LEDs positives. You would end up with 6 positive wires and one ground wire if you have done all of the steps correctly.
Step 7: Plugging In.
Next attach the ground wire to the GND header on yours Arduino.
Attach the furthest away set of LEDs positive wire into pin 13
Next into 12
Next 11
10 and so on until you get to pin 8.
Step 8: Code
I have pasted some free effects I have made myself. It is easy to make your own though! Thanks for reading and have fun! I want to also create more of theise and create a daisy chain of led light bars with this one being the master and the others being slaves. :)
A cool little light show script ---
//Sketch for led light bar
//6 sets of 4 leds
//By Charlie Bolland
int led1 = 13;
int led2 = 12;
int led3 = 11;
int led4 = 10;
int led5 = 9;
int led6 = 8;
void setup() {
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
Serial.begin(9600);
void loop() {
Serial.println(led1);
delay(1);
Serial.println(led2);
delay(1);
Serial.println(led3);
delay(1);
Serial.println(led4);
delay(1);
Serial.println(led5);
delay(1);
Serial.println(led6);
delay(1);
digitalWrite(led1, HIGH); //Start
delay(250); //Effect Scroll 1
digitalWrite(led1, LOW);
digitalWrite(led2, HIGH);
delay(250);
digitalWrite(led2, LOW);
digitalWrite(led3, HIGH);
delay(250);
digitalWrite(led3, LOW);
digitalWrite(led4, HIGH);
delay(250);
digitalWrite(led4, LOW);
digitalWrite(led5, HIGH);
delay(250);
digitalWrite(led5, LOW);
digitalWrite(led6, HIGH);
delay(250);
digitalWrite(led6, LOW); //End
digitalWrite(led4, HIGH); //Effect scroll 2
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(250);
delay(50); //Strobe Effect
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
delay(50);
digitalWrite(led2, HIGH); //Strobe effect 2
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
delay(50);
delay(50); //End
Cool Strobe effect type thing.
//6 sets of 4 leds
int led1 = 13;
int led2 = 12;
int led3 = 11;
int led4 = 10;
int led5 = 9;
int led6 = 8;
void setup() {
Serial.begin(9600);
void loop() {
delay(25);
delay(25);
delay(25);
delay(100);
delay(25);
delay(25);
Woodworking Contest
