Led Light Fixture
Published
Introduction: Led Light Fixture
This simple and useful light fixture is easy to build and cheap.
What you need:
  • White Led Strip
  • Wire Channel Raceway
  • Double-side tape
  • Nylon Cable Ties
  • Screws
  • Wire
Tools:
  • Scissors
  • Knife
  • Cutting Pliers
  • Dremel
  • Soldering Iron
Step 1: Building
Make an arc with cover of wire channel raceway, attach two or three led strip track at this cover using double-side tape and nylon cable ties. You will be need solder wires in tip of strip led to have power continuity. In the tip of arc use drill and milling cutter with a Dremel to make the holes like the picture.
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
