Introduction: Led Personal Sign
Picture of Led Personal Sign
I recently made a entry coat rack for my kids and I wanted them to have the own each personal section.
So I made them each a personal sign. This one is for my son. Its made out of old remote circuit boards and insulation foam and left over led light from other projects
You will need.
1: Something for the name (insulation foam)
2: Razor blade or Dremel engraver
(I used dremel to drill out name cause foam was delicate)
3:Hot Glue gun
4: Led lights
5: 12v Cord
6:(Optional) Switch
Step 1: Get Your Scraps
Picture of Get Your Scraps
This was an extra piece of insulation foam and some old remotes I started with
I measured how big I wanted the sign on foam and worked around it
Step 2: Measure Letter
Picture of Measure Letter
It was an odd measurement, So I made sure I had space on each side, then measured and divided by the number of letters in his name and came up with the sizes of the letters.
Make sure you put some space between each letter :)
Step 3: Drawn the Name Stencil
Picture of Drawn the Name Stencil
After I had a space for each letter I drew the letter where it would not fall out when I cut it.
Step 4:
Picture of
I used a dremel here to cut it. You can use a razorblade to be faster, but I wanted to make sure I didn't tear or break it
I doubt alot of people would used insulation foam or this project, but I was using scraps from other projects
Step 5: Paint the Foam
Picture of Paint the Foam
As seen here I painted the foam.
Its just some acrylic black. This is the point where you can do other details in the name.
Step 6: Add the Circuit Boards
Picture of Add the Circuit Boards
I added the remote circuit boards to the back and hot glue them in.
Make sure to use a low temp on foam, as to high temps will melt the foam
Let dry while you work on the back
Step 7: Get a Circuit Bard
Picture of Get a Circuit Bard
I had a circuit board from a old electronic I harvested the parts off.
I used the sign to measure where to cut
I used a dremel cut off wheel to cut it
Then I added scrap wood for the frame and boxed it in with circuit boards for the sides
Step 8: Add Lights
Picture of Add Lights
I just slapped some random strip of led light I had from another project. I has a sticky back.
These are easy, you can make it battery power or ac for a plug
Step 9: Finished Product
Picture of Finished Product
Now you have your finished product
This didn't cost anything for me.
I guess if I broke it down for what it would cost, It would be about $3
Thanks for looking at my instructable
Please leave a comment or question thanks!
About This Instructable
461views
9favorites
License:
Bio: I like Making computer art. I see beauty in junk. Where others see a sewing table I see a charging station. People saw old motherboards ... More »
More by Izrail:Tron Molding PrototypeUpcycled Industrial Shelf, EasyPyramid Head, Steampunk Style
Add instructable to:
