loading
Want to know how to make a cheap cool sign? Well, your in the right place
Step 1: Gather Materials
you will need:
-sharp knife or blade
-tape
-shoebox
-LED or RGB LED
-Arduino or Battery
-fogged or translucent piece of plastic or glass
Step 2: Cut
take the sharp knife or blade and cut out the lettering or picture you want to have lit up
Step 3: Open the Box
the title is pretty self explanatory
Step 4: Tape the Sheet of Glass or Plastic On
take the sheet of glass or plastic and cut it down to fit onto the lid of the shoe box then tape or glue (which ever works best for you) the piece in place
Step 5: Insert Lighting
if you don't have an arduino just use an LED and a battery to make light. Arduino or any other microcontroller really improve modifications or extras.
Step 6: Wiring
wire up an LED or RGB LED to the arduino like the picture indicates. if just adding an led just wire the negative end to ground and the positive end put between a resistor and a pin on the arduino. The button is just there for messing around you can chose to use it or not.
Step 7: Code
open the arduino IDE on a computer and plug in the arduino
as I said Earlie so simple its probable easier to just use a battery and led. BEWARE TO USE THE CORRECT VOLTAGE WITH YOUR LED if you choose not to use the arduino.
the RGB code:
int r=11;
int g=10;
int b=9;
void setup(){
pinMode(r,OUTPUT);
pinMode(g,OUTPUT);
pinMode (b,OUTPUT);
void loop(){
digitalWrite (g,255);
Step 8: Finish
just turn off the lights, power on the arduino or LED, and admire your work
About This Instructable
575views
2favorites
License:
More by Kale_3d:RFID access system Arduino Calculator CD case calendar
Add instructable to:
