Led Switchback Circuit
Introduction: Led Switchback Circuit
I googled this circuit the whole Internet and not found how to do it, and finally got a simple circuit, and would like to help you
Step 1: What You Will Need !!
  1. 1n4007 Diode
  2. 5 pin car relay
  3. Capacitors 6,600uf (minimum), I used 3 of 2,200 microfarad
  4. wires
  5. led drl for test
  6. soldering iron
  7. electronic skills
Step 2: Solder the Capacitors
solder the capacitor terminals in parallel, positive with positive and negative with negative like the image
Step 3: Connecting on Relay
connect the negative of the capacitor on pin 85 of relay, and the positive on pin 86
Step 4: Positive to Drl
connect the pin 87a on the positive DRL and pin 30 to the positive battery, connect the pin 85 to the negative batery too together with the capacitors like the image
Step 5: Diode
connect the 1n4007 diode on pin 86, as in the picture (the negative side of the pin 86) and connect the other end to the positive turn signal wire
Step 6: You Finished !!!
check out the links are correct, any questions do not hesitate to ask !!!! very simple ...
  • Trash to Treasure
    Trash to Treasure
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
Can I use capacitor of 6600mf, pls share the wiring diagram
Hello i got to the point where the drl turns on, but i cant get the relay to trip so the turn signal leds blink. What am i doing wrong?? Ive done this like. I lost count lol!!
What part did you stop? you checked the wires that go to the relay ?
I did like a thousand times. The relay dosent switch to turn the other light on. How and or where do i use a switch?? Im just confused on that part.
Could this be used to turn off a headlight while the turn signal is activated?
Belo circuito Renan, parabéns, vc pode me ajudar a montar? Qual rele usado entre outros.
Would the capacitance change depending on the type or number of LEDs ?? ?
it does not change, just to keep the relay activated while the turn signal is active, not to blink the two colors together
Nice control circuit. Also great first Instructable. Very well written.
