Led Tester / Current Limiter
Introduction: Led Tester / Current Limiter
I use LED's in plenty of projects and art pieces. I've been caught a couple of times by a bad led so I like to test them first...
I bought a simple tester for small LED's but decided to make one myself for high powered LED's.
Now I know there are plenty of ways to test LED's. Well, here's one more.
It also good for testing small electronic devices of unknown condition.
It's essentially a current limiter with a digital panel meter.
Step 1: Making a Nice Case the CNC Way
I got fancy and used a CNC to cut out the front panel to hold the meter and the switch. A Dremel works just fine too. I'm a little dangerous free-handing with a Dremel so that's why I got the CNC...... I do this with many of my projects. You can even engrave legends and logo's this way.
I used a Compaq 16V laptop supply since I had a few lying around. The meter operational power input is rated for 5-30V so keep that in mind when picking your supply. I attached the meter power directly to the input. You could add a zener diode in series with the meter supply lead to raise the limit a bit to handle 36V input. The meter range itself is 0-100V so a separate and isolated meter supply would allow you to use the full range.
Step 2: Simplistic Design
I assembled mine in a Radio Shack project box. Most people use a potentiometer for variable current control. I took a different approach. I had these SCSI address selector switches in the junk drawer. using a bunch of 10 ohm resistors I made a simple selector. the output current will be the value of the switch times 100Ma.
Some of these switches have stop pins that block certain positions like 0 or 7 and beyond. The stop pins can usually be removed or just relocated. My switches go from 1 to 7 by default so I left them alone.
You could extend this to use BCD or HEX switches by adding another bunch of resistors.
Step 3: Testing an RGB LED
I tested a few RGB LED's. its nice to be able to check the forward voltage of each section too. sometimes I cheap out and use series resistors in my LED drivers rather than current sources. This way I can select the right resistors for each section.
I tested all sections at the 200Ma setting. The RED section was about 7V. The Green was about 9.5V and the Blue was almost 10.5V....
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    Very interesting version of the LED tester.
    . If I am correct, this is to test high-powered LEDs.
    yes, I updated the text to show that. thamks!
