3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Led electric guitar pickup mod *** Updated with schematic for blinking leds and video!
Step 8Optional extra features.
If you want to make it so the leds turn on when you plug it into your instrument cable, all you have to do is get a stereo input jack, you can get these in many places for under $5. With the jack you would put on wire from the battery on the left channel (the part thats in the middle, its like the one that touches the right channel but it touches the ground). next you would connect the other side of your wire to the ground spot on the jack (normally the one with the bigger space). So when you plug in your guitar, the ground spot finished the circuit, there is no difference in sound quality using this method. ** You must still use a mono cable with the jack, a stereo cable with cancel of the stereo jack.
***Hsandford has a guide written up on another way of doing this, It is a bit more complicated, but will produce better results and less problems overall then this method, you can read his guide here. http://howardsandford.com/blog/flashing-leds-audio-meter-avr-attiny-guitar-pickup-wiring-sound-following-circuit/
Also you could make it so the lights blink when you strum, I have Successfully built this circuit and it
works amazingly!
http://www.youtube.com/watch?v=JtR5kkf7ipw <--- link to it in action, skip to the end for me playing it, (I KNOW I SUCK AT GUITAR)!
  • another thing to note is that for some reason, with the blinking circuit it seems to drain your battery even when your not playing, so to prevent this i put a magnetic switch on the positive line from my battery so when i put a magnet on the outside of the electrical panel cover it kills the battery completely.
***** this is the Schematic That works 100%!!! the part that is in red is OPTIONAL, It will make the lights come on more or less, the capacitor there boosts the amplification from 20% to 200%, and if you want it to be 50% add in a 1.2k resistor after the capacitor, you can use any resistor you want, but the higher the value the less amplification you get, wich means your leds will be dimmer!
37 comments
Dec 29, 2011. 9:19 AMPJEC says:
Could you do this with el wire instead of LEDs? It would produce a better distribution of the light I think...
Jun 12, 2011. 8:36 AMawilliam1 says:
hey, i've though about the blinking mod, & i got an idea.
why don't you just use your old "mini" computer stereos' pcb board inside, & hooked up on your guitar. so it goes like this:
1. disconnect the wire on the pcb that connects to the speakers and solder it to a bunch of led your going to put it on your guitar. (don't forget the properly solder the leds according to the + & -.)
2.disconnect the input wire(the one you connect it to the pc or something) on the pcb, hook up a new cable on it & connect it to the guitars output wire.
3. remove the volume knob and just connect the gap with some cables and stuffs.
(if you wanna remove the on of switch too, just do it just like the volume knob)
#got this idea from installing leds on psp. haha",
haven't tried on putting it on my guitar but when i tested just to check of the led blinks when i play the song on my mp3's it work well. so, i hope it works to on guitar.
p.s if there's a problem with my english, sorry. i'm just an 14 years old indonesian boy. thanks :)
Jan 13, 2011. 4:43 PMxxBlackSoulxx says:
where does the GND (negative) go to
Jan 9, 2011. 8:47 PMnextorange says:
I did this project but the leds are direct and not me
blink when I play, is supposed to shine as
I play guitar, I put the LM386 with a capacitor
10uF, and 8 leds THE OUTPUT, which could have been my error?
pdt: excuse me english but I speak spanish :)
Nov 14, 2010. 5:25 AMquinnyt2015 says:
1. Howd u wire all this on a monojack
2. what value resistors are you using
Jun 30, 2010. 6:32 AMhareluya says:
Nice project, I'm trying to do it as well, but put mine in the hole where the Floyd Rose Tremolo sinks... One questions...the LM386n module, you have INPUT +/-, are these from the pick up?? How do I tell which wire it is?? Thanks!
Jul 1, 2010. 12:58 AMhareluya says:
Hi Adem, thanks for the tip. I tried that, but it seemed to sabotage the sound quality a little? Am I doing it right or is there a bad connection? Also, my test on the breadboard seemed to have failed since the LED stayed on, but it did kind of get brighter when I played. Do you know any reasons for that? I'm running a 3mm LED I think it's 3.3v...? The resistor I use is 300k as advices by the shop clerk.
Jul 1, 2010. 3:43 PMhareluya says:
Hi Adem, Thanks for your response, but I'm totally confused...I'm not an electronics person, so this is a little overwhelming...and discovered that I can't even solider...=( I appreciate your help, but yeah, I think I'm totally stuck here...I guess I will have to find someone to help me locally and see if I can work something out...
Jul 14, 2010. 8:35 PMhareluya says:
Hi Adem, It worked! Playing around with it and it worked the breadboard, now I just have to figure out a place to put the LEDs and solder the circuit together...my soldering skills proved to be very very very cr*p.......... Will post pick in tribute to you if successful! Cheers, Simon PS. I still don't understand the diodes, perhaps you want to update your instructions?
Aug 2, 2011. 4:39 AMnalex1 says:
okay, I finally did the circuit, but the LM386 circuit "distorts" the clean signal.
so i followed your diode diagram, used 1n34 Ge diodes, but the LEDs didn't light up at all!
what diode did you use to be able to make this work?
Jul 5, 2010. 3:03 PMandre.caraco says:
Hey Adem70, great instructable, thanks for the diagrams and video. I just have one question still about the pickups (sorry, if I seem inept at this subject). Are you connecting the positive and negative of the pickup directly to the LM 386n and wouldn't this render the pickup useless (no sound output) except for the LED circuit? Thanks for any response in clarifying this for me!
Jul 11, 2010. 3:34 PMramontrndo says:
hello, i just was wondering where could I possibli add the diodes. because when conected to the amp.. the circuit starts to emmit a sound frecuency as I get the treble of my guitar to the top. It only supress the sound when the tone is 0... so I want to try the diodes...
Jul 5, 2010. 3:37 PMandre.caraco says:
Hey, thanks for the help and quick response, I am thinking of using EL wire instead of the string of LED's... can't wait to try it!
Nov 13, 2011. 7:54 AMjpunkäss says:
I tried it and it failed, EL workes on high AC voltage, making high frequency (wireless) electromagnetic noise, that will appear on the amp even feet away!
Jul 14, 2010. 8:33 PMhareluya says:
EL wire will generate a high frequency sound you may find it very annoying.....
Apr 16, 2010. 4:25 AMMusicMan587 says:
Hi!
Nice work!
Could you please tell me which ATtiny85 and transistor npn, used you?
Apr 19, 2010. 12:56 AMMusicMan587 says:
I'm trying to build this circuit (with flashing leds) but i don't understand how:
is it possible to  link the leds directly to the fifth pin of the LM386N-1 or do i have to follow the entire scheme and so to program the ATtiny?
I tried without ATtiny and one led, but this one lights always, ignoring the guitar signal (i linked this one on your input +).
Let us know the right wiring way please ;-)!!!
Apr 9, 2010. 7:22 PMRF567 says:
 I have an idea. Use a swich just like a rhythm/lead switch on a guitar (but three ways) and wire it up so that you have three channels, so to speak; one for an "off" channel, one for lighting up when you "play only", and one for an "always on" channel. Not sure if it'll work though
Apr 9, 2010. 7:29 PMRF567 says:
 oh by the way, where abouts do the resistors go? I don't know (I failed physics at the end of year exams (this is in a country called New Zealand (Its by Australia - I don't know how you guys do things over in America)))
Dec 23, 2009. 10:51 AMandersh says:
Thanks for this, a relly good project. I am trying this at the moment and have 2 questions, the battery gets pretty hot - is this normal? also, as soon as I connect it up the LEDs are lit. They do get brighter as I play but I'd like them to be unlit until I play if possible.
Cheers.
Dec 13, 2009. 5:41 PMdoublett says:
What is heat sinking do you need to do it for the chip.
Dec 8, 2009. 5:22 PMbobbyderf123 says:
I Dont Get ANY Credit?!
haha just kidding
Dec 9, 2009. 4:12 PMbobbyderf123 says:
haha, yeah but its a good thing you explained it in your instructable cause i think you explained it better than me
Jun 20, 2009. 11:44 AMbobbyderf123 says:
pic
Jun 28, 2009. 8:18 AMbobbyderf123 says:
you can get the stereo jacks from radioshack; 2 for around $2.50 So do you get what im saying though? : )
Jun 28, 2009. 8:20 AMbobbyderf123 says:
but u only need one for the project (obviously) i hope u didnt pay mor than a dollar for it(otherwise youd be getting ripped off
Jun 20, 2009. 11:45 AMbobbyderf123 says:
youll have to click on the pic to see it well
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:adem70
