The one that inspired me was by SlickSqueegie: http://www.instructables.com/id/Shop-mad-bench-vice/ The only obstacle I had was getting a acme threaded rod long enough to do the job. I searched for a while but couldn't get one without paying more than the price of a cheap wood vise (like this one). At some point on this search I had a moment of engineering clarity: I have one of those quick-grip bar clamps , why not use that instead of a screw... so I 'invented' a vise with a low pivot and place for the clamp.
Naturally I had not invented anything, the leg vise has been used at least since the 18th century, see the second picture above. This is a good thing because I could research different styles of leg vises and modify my design.
I've also created a 3D model of this vise, so if you'd like to see it all in more detail you can download it here.
Remove these ads by
Signing UpStep 1Plan / Design
I've included my dimension sheet in the second photo but this will vary depending on the size or your workbench.
Instead of a bar clamp, could the hardware for a pipe clamp to be welded to the forward steel cross beam that would float in and out with the forward jaw? That way, the clamp wouldn't stick beyond the outer jaw and the slide part of the clamp would stay with the rear steel under your bench and out of the way. to tighten it, the bar clamp adjust screw could push against another steel bar that's securely attached to your outer jaws. The angle iron you show in your photo would slide partially out of the grooves in the vice's jaws as the jaws move backward, tightening against the work piece being held.
btw, Did you get the pictures of the speed vice attachment I made from your Instructable? By using spring steel wire, it's clean and works beautifully... Because the handle is wood, it was possible to add an additional aid to make everything faster yet:) (the crank is a 5/8" dowel. I thought it might get in the way, but it rotates down 90º and out of the way (and stays that way) until it's needed again. I love your idea... Next will be my 3-1/2" bench vice.
Here's what it looks like, plus I also wrapped the handle of a bar clamp (hard to see, but check how I hid the wire ends). If markbyounger (it IS his thread, after all) decides he can use a bar clamp with his unique setup, it would also have those capabilities.
If you enjoy reading this is something I have found inspirational:
http://www.history.rochester.edu/ehp-book/shb/start.htm
Shows what hyper clarity of vision can accomplish! The body of work speaks better than I can, but I'll just say since I finished it I've looked at everything differently.
I'm looking forward to reading it.
I bet he was a real SOB IRL still, it would have been cool to have known him personally.
Oh, and for acme thread look to some car jacks. Some of those have suitable threaded rod and nuts that you might have to do some elaborate joinery to use, but can be made to work.
I have a whole collection of dogs I made plus plugs for my whole bench and I still have half the 3 foot long dowel left over. So the argument that with square ones you can rip your own is moot. Oh here is a picture of when I put the dogs in my bench. You could say I wanted them nice and square. it really went pretty easily with that setup.
