3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Legend of Zelda Treasure chest with sound!
Step 5Hinges, Trim, and Detailing.
  • last photo ←
Before you add any details you'll need to add your hinges. I used hot glue to attach mine, it shouldn't be too difficult.
Once you've got your hinges installed you can start adding the details. There are a lot of lines that I chose to add with a sharpie marker instead of actually using multiple pieces of wood. One could argue that you should just cut more wood pieces to achieve these lines, but it's a lot less work to use sharpie, and a lot easier to do.
After you've added your detail lines you can add For the black trim around the edges I cut 5/8" strips of my black posterboard. After cutting the strips to the proper lengths, I used small dabs of super glue to attach them to the chest. You'll need to cut some angled pieces for the trim on the sides of the chest lid.
Once you've glued all the trim pieces on, you can start adding your furniture nails. You'll need to cut the nail part down to about 1/8" with your wire cutters or pliers. The furniture nails I used were too long otherwise. I just shoved the furniture tacks in by hand. If you're having a hard time pushing the nails into your chest you can drill holes for them. I didn't have to however.
For the Keyhole, I simply cut out a rectangular piece of posterboard, 2 1/2" x 1 3/4" and cut a key shaped in the center and glued a glossy piece of black paper behind it.
If any of your posterboard edges are white, you can go back and very carefully black them out with your sharpie. I did this in a few areas to make things look nicer.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
54
Author:Zachariah Cruse(Zachariah Cruse)
