Legend of Zelda Triforce Chainmaille Dice Bag by RabbitDance
Contest WinnerFeatured
Just the thing for your rupees or your dice!
In this Instructable you're going to learn how to make a chainmaille dice bag with a Triforce on both sides of it. The bag you see is the finished item and can easily hold five standard sets of D&D dice, with room for more. It's holding 61 dice in the photo, to be exact. I have notes for ways to modify this pattern to suit your needs, too. Feel free to experiment!
This project assumes some basic knowledge of chainmaille but I'll be including tips throughout for those new to the craft, so don't let it intimidate you. As I always say, "Making chainmaille isn't hard. The hard part is actually finishing it."
Step 1: Tools & Materials
Tools:
2 Pairs of Pliers *
Not pictured - Scissors (to cut the drawstring later)
Materials:
1100 Green anodized aluminum rings - 16 ga. 1/4"
200 Gold anodized aluminum rings - 16 ga. 1/4"
Drawstring material - I use leather cord
Drawstring stopper - You can find these in the "Sewing Notions" area of most craft stores. You could also use a large-hole bead for a more rustic "period" look.
Not Pictured - PATIENCE
Optional:
A single 16 ga. 5/16" ring for the base. You could use one of the 1/4" rings, but it's kind of tricky to start and doesn't look as good.
Note: The ring amounts I give are rounded up to the nearest 100 to account for things like plier slippage, mis-cut rings, anodization goofs, etc. Better to have too many rings than too few!
* I strongly recommend bent nose pliers, but really any pair of pliers with smooth flat jaws will work. Don't use pliers with round jaws or those with teeth, as these will mar the surface of the rings and possibly scratch the anodization clean off.
doxsys says: Apr 19, 2012. 2:12 PM
This is simultaneously 1) OUTSTANDING, and 2) possibly the geekiest instructable I've seen yet (and there are A LOT of geeky instructables, in case you hadn't noticed.) The triple-whammy of chain mail, dice bag, AND triforce is totally over the top.
Keep up the terrific work, BTW. :)
chaoszerom says: Feb 6, 2013. 2:00 AM
Do you think that this will work with rings of AR 4?
RabbitDance (author) says: Feb 24, 2013. 11:42 AM
I don't see why not. It's not far off from what I'm using, but the base might be a bit dense when you start. You might need to use a different ring size as your base ring like I did in the tutorial.
Medelle says: Feb 3, 2013. 4:27 PM
I'm making this for my husband and I've gotten to row 7 and it feels crowded where I finished the last row. Something I've been a little confused about is if I'm supposed to try and join the end of one row to its beginning or does it just kind of overlap. Will this make a seam? If I made a mistake earlier on... I just might throw it out the window. : )
RabbitDance (author) says: Feb 24, 2013. 11:36 AM
They should overlap like flower petals. And luckily chainmaille is very forgiving when it comes to mistakes. Just take out the rings above the oops, fix it, then fill in above it. I know I could give better advice if I could see a picture.
cryptex says: May 19, 2012. 4:12 PM
could you make other patterns like a shield or a insignia
RabbitDance (author) says: Feb 24, 2013. 11:32 AM
Of course. I've made bags with runes, flowers, spirals... Just make sure it'll read well in the finished product and you're good.
thecyberking says: Jan 13, 2013. 8:54 AM
chainmaille bikinis?
RabbitDance (author) says: Feb 24, 2013. 11:21 AM
Yep. Many, many bikinis. Including the bottoms!
Medelle says: Feb 5, 2013. 11:46 AM
This isn't the part I find tedious... OPENING JUMP RINGS I find tedious. Seriously - I'm having nightmares about it.
cryptex says: May 19, 2012. 4:13 PM
loving the bikini
unknowen says: May 14, 2012. 12:06 PM
I just finished this for a graduation present for a friend. I'd never done chain mail before, but this instructible was perfect! The bag came out amazing, it looks just like the pictures. Thank you!
Chronos2187 says: Apr 26, 2012. 7:49 AM
Very interesting Ible. Whenever i make bags i usually do 2 squares and then join them. I'll have to give this a try. Thanks for the great Ible.
lordwekner says: Apr 25, 2012. 6:12 PM
" Panic at the sudden appearance of pink rings."
Laughed so much:P so going to do this right now!!!!
furrysalamander says: Apr 15, 2012. 5:05 PM
So if I were to buy from the ring lord, what would I need to order to make a shirt? I can't decide what metal, and I don't know what/how much I need.
Ainda says: Apr 23, 2012. 5:26 PM
Hi, was in the sculpting team for masks, costumes and gadgets for a larger role playing group + spent a couple of years in re-enactment (early middle ages)... you will need a lot of rings! some tips: if you don't need to be concerned with historical accuracy: go for light metals... the weight adds up!! We used to make our own rings (cheaper!!) by simply rolling it around a stick and cutting them, you might need to finish the endings, but if you have time, patience and a tight budget it's the way to go!
Aluminium is light + shiny, but go to the local hardware store and check all the metal wires you can find... they shouldn't be too flexible.
One more tip, ones you finished you're shirt, it'll get dirty. if you clean it with a brush, it'll get a nice shadow/ airbrush effect... if you want it shiny like new... put it in an old fashioned potato bag with clean dry sand. close the bag and move it around... or even better invite you're ring lord friends and play some games throwing the bag around... it'll be like new :-)
and lastly... if you are going to wear this shirt, make sure you have a padded shirt under it!!! it'll keep you safe from hundreds of little bruises.
PS Rabbit dance: brilliant design, loving it!!! I admit being a bit jealous I never thought about making gadgets like that!!
RabbitDance (author) says: Apr 15, 2012. 8:25 PM
If you've never made chainmaille before I wouldn't recommend that you make a shirt right off the bat. I would compare it to volunteering to make Thanksgiving Dinner when you can hardly be trusted with a microwave (like me!) That's just my little warning, as rings can be expensive and it is a huge time investment.
Anyway, that said, here's what I recommend:
If you're making your shirt for costume purposes, go with bright aluminum. My husband does stage combat with a local theatre troupe and the bright aluminum maille shirt he wears looks great on stage! It's also light enough that he can do all the cool stage moves in it with no problems. Aluminum is a lot easier on the hands and the whole shirt weighs about 10 pounds. The steel shirts that I've made average around 30 pounds.
As for how much you need, that depends on the final shirt size, the design (total length, sleeves/no sleeves, etc) and what size ring you want to use. The Ring Lord has kits available with instructions on making shirts. Look in their "Projects and Kits" section and have a look at their Chainmaille Armor kits. If you like the look of what they have up, I'd say just buy the kit and maille away! If you want something different (like longer sleeves, a pattern inlay, etc) you can use their ring sets as a guide and buy your rings accordingly. There are plenty of shirt patterns out there too, so look around. I recommend mailleartisans.org and deviantart.com for inspiration in that respect.
furrysalamander says: Apr 17, 2012. 2:39 PM
What metal is cheapest/is best though? I was also planning on something more like a t-shirt that could be worn over my regular shirt.
GinaLeger says: Apr 15, 2012. 8:02 AM
where did you buy the links?
RabbitDance (author) says: Apr 15, 2012. 9:04 AM
I buy my rings from The Ring Lord in Canada. Their website is http://www.theringlord.com
The rings you see here are the machine-cut ones. I like the depth of color better as opposed to the saw-cut. If you want some heavier contrast between the Triforces and the background, you can get machine-cut green rings (which are slightly matte) and gold saw-cut rings (which are really shiny) for the Triforces. But be aware that saw-cut rings can be trickier to close because they have a wider kerf. It's not any more difficult, but it does take more time to do.
Fred_is_Dead says: Apr 15, 2012. 6:28 PM
But the saw cut are cleaner to close if you have the time and experience. Personally, I avoid ordering the machine cut just because the ends are usually rough and choppy. That's just me, though.
RabbitDance (author) says: Apr 15, 2012. 8:38 PM
I tumble all my rings whether they're saw or machine cut, and that takes any nasty bits right off.
But I do love the saw-cut rings, especially how seamless everything looks once they're put together. I only wish their colors were richer, else I would use them more. (They used to offer enamelled copper in 16 ga. Oh, how I miss those jewel tones!)
Fred_is_Dead says: Apr 20, 2012. 5:50 PM
Oh, you're a lucky one with a tumbler. I have to do without (mainly 'cause I'm too cheap to buy one) so I stick with the saw cut.
Lil wenchie says: Apr 19, 2012. 9:10 AM
This is SO amazing! I've only ever done a chainmaille bracelet before, but I'm desperate to give this a try and your instructions are so clear! Being in the UK though, I'm guessing it's going to cost a bit to get the pretty rings to me :(
TheGreatS says: Apr 15, 2012. 1:04 PM
OOOOOO AHHHHHH. I totally need to make this, but ... there are so many links!(pun intended)
RabbitDance (author) says: Apr 15, 2012. 9:22 PM
You can do it! ^_^ It's only about 1200 rings. The amount of rings I used fits inside of a small butter tub. If you cup your hands the rings will fit in it.
Marathon the Lord of the Rings extended editions and you'll probably be done (or very close to done) by the end of them! That's what I did. ^_^
Penolopy Bulnick says: Apr 15, 2012. 4:40 PM
Awesome! And I love how bright your pictures are, it makes it really easy to see what you are doing and follow along! :D
GinaLeger says: Apr 15, 2012. 9:33 AM
Thanks a bunch!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
