Legend of Zelda Triforce Chainmaille Dice Bag
 by RabbitDance
FeaturedContest Winner
Step 4: Assemble the Triforce!
Now you can pull out your gold rings, but keep your green ones handy. We'll still need them.
Before you begin: Open a bunch of gold rings and some green ones, but more gold than green.
Picture 1 - Begin the Triforce
Take 14 gold rings, and put them on the edge just like you were for all the rows before it. This is the base of your Triforce. I say 14 because I want some space between my Triforces (remember, there will be one on each side of the bag) and because I'm superstitious when it comes to gaming. Having 14 rings along the bottom means there will be seven rings at the base of each triangle that makes up the Triforce. Lucky!
Picture 2 - Row 2 of the Triforce
Add on 6 gold rings, 1 green ring, then 6 more gold rings. Your Triforce is well on its way! Just so you know, this row has 13 rings and your rows will naturally decrease in size by 1 ring as you go on until you end up with just one ring at the tip.
Picture 3 - Triforce Base
Like before, just keep adding in rings so they go through two rings under it. I hope the pattern is fairly easy to see here in the picture, but just in case it's not, here's a..
Row-by-Row Breakdown
Row 1 - 14 gold
Row 2 - 6 gold - 1 green - 6 gold
Row 3 - 5 gold - 2 green - 5 gold
Row 4 - 4 gold - 3 green - 4 gold
Row 5 - 3 gold - 4 green - 3 gold
Row 6 - 2 gold - 5 green - 2 gold
Row 7 - 1 gold - 6 green - 1 gold
Picture 4 - Triforce Top
You'll only need gold rings for this part. Start by adding on 7 gold rings. Keep going, decreasing each row until you reach the top and have only one gold ring left. Guess what? YOU MADE A TRIFORCE! Now turn your base around and do it again on the other side, making sure to have even space between your Triforces. You'll end up with a circular bit with two triangular flaps coming off the sides. Put it on your head; it's fun! ^_^
Is your base bigger?
That's okay! Just make the gold base rows wider. Keep in mind that it will have to be an even number of gold rings so you end up with two triangles that are the same size on the bottom. If you're not sure how wide to make it, fold your base in half and set it down. It'll kind of "bowl up" when you do it. Look at it. Use your eye to determine what "Looks Good" in terms of base size, and you're all set.
A Note about Construction:
There are several ways to go about this phase of construction. Some maillers go ring by ring, completing each row before they go on to the next. Others will start a brand new flat panel of maille and stitch it onto the base once they're finished. Still others like to do as we are here, by making a small panel with their pattern on it, and filling in the "background color" once their patterned area is done. I tailor my technique to the pattern I'm doing. Complex patterns get charted out and made flat, then stitched to the base. Simple geometric patterns are done row by row, and small panels of patterned inlay (like our Triforce here) are made individually before I fill the edges in. I guess what I'm really getting at is there are many ways to go about this. Just do what feels right for you. For this particular bag, this method is really easy to photograph.
Oh, and you have no idea how happy I am to use the phrase "Assemble the Triforce" in a legitimate fashion.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
