Lego 3D Printer 3.0
13,957
173
19
Published
Introduction: Lego 3D Printer 3.0
About: My name's William and I love robots and everything regarding automation. I also enjoy music, drawing and debating.
Hi there!
A few months ago I've built the 2nd version of my Lego 3D Printer, and today I'm going to show how to build the 3rd version.
Step 1: Watch the Demonstration Video (optional)
Step 2: What You'll Need (for the X and Y Axis)
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Don't forget the Lego doors for equilibrium
Step 9: What You'll Need (for the Z Axis)
Step 10:
Step 11:
Step 12: What You'll Need (for the Extruder)
Step 13: Don't Forget the Gluegun AND the Paper Clip
Step 14: The Extruder Should Look Something Like This
Step 15:
Step 16:
Bend the paper clip in a way that it partially stuffs the hole of the gluegun nozzle. This will allow for a more controlled extrusion process.
Step 17: Voilà
Step 18: Tipp
Use elastic bands to strap the paper (on which you'll print) to the moving platform
Step 19: The Result of My Test Print
Step 20: The Mindstorms Code I Used for My Test Print
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    19 Discussions
    The metaphor of a 3D printer being a CNC glue gun has been floating around for ages.
    I think it's brilliant you made a 3D printer with an actual glue gun!
    Thank you for making the metaphor real.
    Mindstorms are too expensive to use in this way. I just checked price for a set $300.00+ per set. your printer with glue gun is very neat and I enjoyed your videos. If I am wrong on price I am sorry was just what I found on their web site.
    Do you have a parts list? Pictures reall don't help when trying to ID Lego parts
    The point of my 3D printer was to be made in the simplest way possible, using cheap material (although I admit the Mindstorms brick isn't very cheap)
    they only cost $20 or so you can actually 3d print objects with printer fillmient
    also, you might not want to make other accounts and comment yourself. (It doesn't look to good)
    :) (i dunno the comment "This looks awesome. I never knew you could actually do something like this... keep going, because I think that if you use the mindstorms 3.0 with this one, it would look awesome!" -WilliamR79
    In the anglophone world, there are millions of people called William. So one of these several million people commented my printer. So what?
    ookkkkk...... that my friend, will take Forever
    The tip is to far off the surface,way too much glue is being pushed out of the gun,and speed up the motion to reduce the thickness,you my want to mod the tip by using a fine ball point pen tip with the ball drilled out,insert this into glue gun tip use a bit of hi temp epoxy to hold the tip in the glue gun tip
    mchau2
    2 years ago
    this is a crazily experimental project! maybe benefitial to print in larger scale to compensate the lack of control and resolutions... total thumbs up!
    lol - I had just the same idea. But I guess the resulting output would still be to thick to be really useable. However, an awesome build. Lego is marvelous.
    Sorry. *If it wouldn't interrupt your your use of your hot glue gun, you could try making a cone of sheet metal just as large as the glue gun tip and snipping the very top of it off so you had a very precise nozzle and welding it to the glue gun.
