Introduction: Lego Candlestick
Picture of Lego Candlestick
How to make candlesticks shaped Lego brick.
Idea: I created these candlesticks to make homemade Christmas gifts.
Description: Made of medium (MDF), they welcome one, two or three candles (tealights). They are nestable and flexible to create all possible combinations! They are painted white or black and covered with clear varnish.
Material: MDF 15mm, paint, varnish, wood glue
Tools used: Circular saw, miter saw, drill press with hole saw, router, hand tools ...
Video:
Step 1: Cutting Parts
Picture of Cutting Parts
I used my table saw to cut 6 cm slices.
Then I cut the lengths of 6, 12, or 18 cms with my miter saw. I attached a stop to have pieces of identical size.
Step 2: Drilling Holes
Picture of Drilling Holes
For the locations of the candles, I used a 40 mm hole saw attached to my drill press.
Again I used a stop to guide the parts and chainwork.
Tip: To sand the inside of the holes, I glued a piece of sandpaper on a PVC pipe !
Step 3: Gluing
Picture of Gluing
The elements are glued with wood glue and sealed with clamps
Step 4: Rounded
Picture of Rounded
All sides are sanded and then I use my router attached under the bench to round the corners.
Step 5: Gluing of the Studs
Picture of Gluing of the Studs
I created a cardboard template to identify the location of the studs, then I glue them with wood glue.
Step 6: Painting
Picture of Painting
The candlesticks then receive:
  • 2 coats of wood primer
  • 2 coats of paint (black or white)
  • 1 coat of clear varnish
Light sanding is done between each layer
Step 7: Done!
Picture of Done!
Done! I then added the tealights and made gift packages to offer Christmas!
I also kept some to decorate the party table.
How to Knot (author)2018-01-16
Cool idea!
Penolopy Bulnick (author)2018-01-12
That's such a fun design! I wonder if it would work to make a raised circle with a hole in it to put the candles in too :)
Thank you Penolopy! Yes why not, we can imagine lots of combinations!
About This Instructable
821views
7favorites
License:
Bio: Passionate of DIY of any kind, I am not of the trade (I am developer in computing) but I am self-taught and I like to ... More »
More by MagicManu:Lego CandlestickThe Mini Wall: the Electronic GameMotorized screw organizer with jam jars: The Caroustore
Add instructable to:
