This candy dispenser provides a fun way to get a delicious sweet treat. A simple slider mechanism doles out the goods and the top has an easy-releas...
The Lego Candy Dispenser takes a variety of parts to make but since there's aren't many specialized or rare parts, most people should be able to build...
Construct an 8x8 base of bricks topped with plates. I used 8 2x4 lime bricks and then topped it with 2x2, 1x2, and 2x4 orange tiles. Whatever parts y...
Arrange a layer of four 2x8 plates into an 8x8 square. Connect the plates using 2x2 tiles offset by one row of studs. Attach the lid to the top of the...
Make the slider by laying out plates as shown. Top with a layer of bricks. Top that with a tiles but be sure to leave 2x2 gaps on the ends. Make two...
Push the slider into the model. The 2x2 opening needs to be closer to the end with the 2x3 sloped ramp. Add the second stack of studs to the other end...
This candy dispenser provides a fun way to get a delicious sweet treat. A simple slider mechanism doles out the goods and the top has an easy-release lid. The Lego Candy Dispenser is a super simple build and doesn't take a bunch of crazy pieces but still results in an impressive way to share your candy with friends.
The dispenser is made of four main parts:
-base
-reservoir
-lid
-slider
The steps are labeled accordingly.
Step 1: The Parts
The Lego Candy Dispenser takes a variety of parts to make but since there's aren't many specialized or rare parts, most people should be able to build it without trouble. While the exact parts and color you use will likely be different than mine, the basic part types you will need are:
-plates
-bricks
-1x1 round plates
-2x3 sloped bricks
-tiles
-1x2 window thingies
Check out the picture captions for the part names.
If you have any trouble with obtaining the transparent parts, you could always use transparent bricks or only make one level of transparent bricks and close the rest in normal bricks, the candy won't be as visible but you'll still be able to see inside.
Step 2: Base
Construct an 8x8 base of bricks topped with plates. I used 8 2x4 lime bricks and then topped it with 2x2, 1x2, and 2x4 orange tiles. Whatever parts you use, aim for strength by covering as many cracks as you can with the plates.
Step 3: Base
Make 4 stacks of 2 2x4 bricks each. Attach these to the left and right side of the base.
Step 4: Base
Connect two 2x3 slopes using a 1x4 plate.
Attach four 1x8s to the 1x4 plate.
Add a 1x4 tile to one end of the base.
Connect the slope/1x8 piece to the base.
Step 5: Base
Add a layer of bricks on top of the model. I used six pink 2x4s.
Step 6: Reservoir
Now it's time to prep the transparent pieces. Make stacks of 3 window thingies to make 12 sets total. Stack 19 1x1 plates to make 4 stacks total.
Step 7: Reservoir
Attach 3 sets of the window thingy stacks to each side of the model. The 4 stacks of 1x1 plates go on the corners.
Step 8: Reservoir
Attach four 1x6 tiles to connect the sides of windows. The 1x1 tiles will make the lid stick on but the tiles will make it easy to take off.
Step 9: Lid
Arrange a layer of four 2x8 plates into an 8x8 square. Connect the plates using 2x2 tiles offset by one row of studs. Attach the lid to the top of the model.
Make two towers of 5 studs each. Attach one tower in the middle of one of the 2x2 gaps.
Step 11: Putting It All Together
I'm not all that into Lego but this looked pretty awesome :) It seems easy enough to mod but, for this, I'd only suggest something for the windows to rest on. They look like they are freestanding! 5/5 because I'm not too lazy to put something to hold the windows in place myself.
What a Lego artist you are! This is so clever an idea, I could just see kits coming out made by Lego Co. I looked at the other lego ideas you have and I have to say you have a very creative mind, and are very good at making a clear instructible. Thanks for posting this!
Chris
PS: You definately earned a quadruple 'very kool' on this one!
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Chris
