Lego Charging Dock
Published
Introduction: Lego Charging Dock
About: I like creating things to make small things easier in day to day life my models and mostly made from lego so you might see a me around the block
This is a compact little gadget that is compatible with iPhone/iPod using it as a cradle whilst charging your device it isn't overpriced like the official docks but works just as well and you can also say that you made it!
Step 1: The Base
The dock will be no wider than 8 studs put bricks together to make a 8x4 stud rectangle
Step 2: The Wire Gap
Decide which side will be the back once chosen use a 4x1 and a 3x1 to create a gap also put 2 flat pieces together and put them in the gap
Step 3: The Walls
Use several ?x1 blocks to create a wall to hold your charger end
Step 4: Securing the Connector
Depending on if your using a genuine cable or not this should work with the cheap cables they will fit stug in a 4x1 gap you may need to use some sort of adhesive to hold it even bluetack works! Use 2x L shape blocks and place them on either side then use a 6x1 block for the back rested on 4x 2x1 blocks inside the gap
Step 5: Hooks and Crannies
Add more ?x1 blocks round the edge to make it all flush if you are adding the sim tray pin hook add a hook block or 2
Step 6: Finishing Touches
Add smooth flat blocks to make it flush with the end of the connector this also allows your iphone or ipod to connect properly
    • Make it Move Contest
    • Pets Challenge
      Pets Challenge
    3 Comments
    No glueing required?
