3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lego Combination Safe
Step 5The Last Steps
The Last Steps
  • last photo ←
1: Build the walls of the safe, and add the door. Do it with bricks with one in width. Be careful when building the walls, because you need to loosen the openings between the 4x2 bricks everytime, to get the bars between them. If you loosen them, don't pull them out of eachother too far, because then you'll break a rotor! And repairing is hard as you can hardly reach the rotors after a while. So contstantly keep checking if the rotor pieces are still together, because later on, you won't be able to reach the rotors at all and you can't repair them; so you don't want them to break them due to weakening during this step.
2: Place two layers of plates on it. Plus a holed place for the stave to come through. And leave a 2x2 gap around the axis between rotor 1 and the dial.
3: take a 4x2 plate and place two flat round plates under it.
4: Slide it on the stave.
5: Change the composition of the springs like this! In my first design, there was so much pressure, that the door would fly open fast, but it would fly off aswell. So if you like that, you can keep it the way it is, but i recommend to chache it like this. The connection sticks on the bottom are both moved one hole to the outside, as well as the black connection sticks above it. The spring are upside down, so that the grey solid part touches the black sticks - if the spring part touches the black stick when compressing, the movement may stagnate.
6: In the door, place a flat 2x1 tile, to let the opening of the door run more smoothly.
7: It's finished!
8: Optional: If you have lego crocodiles, you can place them on top of the save, to scare lockpickers off.
12 comments
Jul 20, 2011. 8:54 AMjhawthorne1 says:
forgot ma com and why cant i breack into mine
Jun 28, 2011. 3:54 AMakõre1 says:
its so so COOL ,i want to bild it but i can t
Jul 25, 2010. 11:11 AMfreecell64 says:
Lol i like it the only issue is i would hate to have it fall tile floors are not nice to legos at all
Jul 15, 2010. 7:40 PMknexguns656 says:
I made 1 but i modified it a bit it on regular hinges and to open it u have 2 decode a message then press a brick but its really tricky to find!!
Nov 14, 2009. 5:58 PMalmcgo says:
i dont hav the right parts for the hinges on the door and ive tried 5 difrent othr ways but i cant find one that works. can u post another way???
Nov 8, 2009. 5:09 PMadx00 says:
im gonna try to build it but i might need a simpler version
Sep 8, 2009. 8:49 AMyzZzy says:
its so cool i bild this in the future
Aug 31, 2009. 10:41 AMThe Jamalam says:
Really nice! I never could work out how these worked, but it's really cool!
Jun 29, 2009. 8:02 AMI3uckwheat says:
love the aligators i have some so i will do this and put it into a moat i have ill take some pictures of it
Jun 27, 2009. 4:39 AMScoboy says:
LOL lacoste
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
167
Author:merijnvw(my company)
I'm Merijn van Wouden and I live in The Netherlands. As my job I make websites. I study Artificial Intelligence.
