Introduction: Lego Door Knob
A fun and simply project to give a kids room their own personal door knob.
Est. project time: 15min plus glue dry time
Step 1: Lego Door Knob
Materials needed:
Legos (this one was made with all 2x4 and 2x2 bricks)
Marker
Ruler
CA glue (or epoxy)
Putty
Brad Point Drill bits
Step 1:
Layout your legos in a pattern that is colorful and close to shape of door knob
(you can get much more creative if you have different shaped bricks)
Step 2: Lego Door Knob
Step 2:
Glue together your legos (skuff sand bricks for a better glue bond)
Have a napkin near by to remove squeeze out as quickly as possible
Glue the bottoms to help with strength.
Step 3: Lego Door Knob
Step 3:
Layout knob and glue together
Step 4: Lego Door Know
Step 4:
Fill the center section with putty (Durhams water putty is real strong)
This area will be where the new knob will connect to the old.
I replacing the inside knob since it has no spring to try to recreate.
Step 5: Lego Door Knob
Step 5:
As putty hardens up you can slide the center bar into make a snug fit.
If you wait to long a 3/8" hole does a good job.
Step 6: Lego Door Knob
Step 6:
Transfer hole locations from original door know and drill them out with a brad point bit to avoid bit wandering.
Step 7: Lego Door Knob
Step 7:
Attach new baseplate to door just like you would a regular door knob.
Make sure glue is dry before trying to tighten to much.
Step 8: Lego Door Knob
Step 8:
Adjust depth of center hole to proper depth.
Step 9: Lego Door Knob
Step 9:
Screws are now hidden. Make sure you left clearance to turn knob without sticking.
Step 10: Lego Door Knob
Hints I have found during building:
- Make sure you completly cover the old door knob hole
- One of the knobs has a spring, so make sure to keep that one (it can be switched to the inside of the room if desired)
- A standard door knob set is made of knobs that connect together and squeeze tight on the door. This one involves a seperate baseplate. Because of this you may need to glue the center shaft onto the knobs (use something removable if you need to work on the door knob)
Finalist in the
Toy Building Blocks Contest
