I was screwing around with some of the motors from my old Lego Mindstorms kit, and discovered that when two motors were directly connected to one another the spinning of one would cause the other to spin too. It was obvious once I realized what was going on, but still strange to see the other motor spinning without being connected to anything but the other motor.
Step 1: Parts
The only things really needed to do this experiment are the motor and the power wire connector. To demonstrate on a second motor you need a second motor, to measure the voltage you need a multimeter, to demonstrate on an LED you need an LED, etc. A rubber wheel is also a good idea because it will be easier to grip then the axle coming from the motor.
1-40 of 97Next »
mpnb402 says: Sep 3, 2010. 9:28 AM
you should put one of those motors at each wheel it will make it 4 wheel drive. and what motors are using
BobQDobbs says: Dec 18, 2007. 11:28 PM
I'm 38 yrs old and have never had a car drivers' license. Excuse me if I'm off here - and please correct me. It has always puzzled me why there are no magnet generators installed on every wheel that spins on every vehicle that travels - cars - bikes - trikes - shopping carts?. Now I know I'm getting a bit hyperbolic but - really - why is this energy wasted. Another thing I will just throw out there is if we could use capillary action (or some other currently overlooked action) to raise water above sea level we could harness the power of it's descent through big pipes (think flushing the toilet) to drive turbines. Nice post sir.
knektek in reply to BobQDobbsFeb 17, 2010. 1:59 PM
they dont use them in shopping trolleys because people can jack/steal them.
godofal in reply to BobQDobbsJan 3, 2010. 6:36 AM
ever ride  a bike with the dynamo (for the lights) on?
ul notice that ul have to kick harder, so, more energy used, for less energy output.
on a car, this already is being used for things as the battery (for starting the engine, lights, dashboard, etc) but the energy that is needed (gas/diesel) to generate other kinds of energy (elektricity) is equal, but mostly a bit less since theres a small resistance from the wiring.
so, it would actually wasting energy...
i already thought of  that, and its a nice experiment :)
btw, if ul make this experiment (with that lego thingies) large enough, ul notice that the second engine is *slightly* spinning slower...
junits15 in reply to BobQDobbsAug 26, 2009. 5:02 PM
its like one of those free energy machines, they don't work =)
hoihoi151 in reply to BobQDobbsAug 9, 2009. 12:27 AM
because driving the magnets would effectively slow down what ever u are moving and more energy would be needed to move it. thus being completely pointless
catprog in reply to BobQDobbsJun 2, 2009. 7:10 PM
there is a big generator attached to the wheels through the axils and gears called an Alternator
hoihoi151 in reply to BobQDobbsJan 11, 2009. 9:58 PM
no offense but that is the most ridiculous thing i have ever heard. ok where would they store this electricity and how would they transport it off the shoppin cart or item of choice? and its really expensive for very little electricity. also raising water above sea level isnt as easy a turning on a tap. and ur now what 39 or 40. GET A DRIVER LICENSE. what is stoppin u from driving?
Jaycub in reply to BobQDobbsAug 12, 2008. 9:22 AM
How would you get the wick to release the water when using the capillary effect?
Stanislaw in reply to BobQDobbsJul 29, 2008. 6:53 PM
that is essentially how the alternator works
Techno23 in reply to BobQDobbsJul 17, 2008. 2:47 AM
That's how all hybrid cars work now, I beliebe - when they're free-rolling the momentum charges the batteries.
sheepborg in reply to Techno23Jul 28, 2009. 7:17 AM
only when brakes are applied plus it is not set up to collect on every wheel if there where 'good' enough batteries and enough of them it would be beneficial to collect power from every wheel btw: alternator is only from the engine spinning (as for you hoihoi151 I am 14 years old)
ramses in reply to Techno23Jul 29, 2008. 1:34 PM
they use the turning of the wheels to generate electricity only when the brake pedal is applied. that is why they don't do much better than normal cars on the freeway; you dont break much
Noodle93 in reply to BobQDobbsJan 15, 2008. 4:12 AM
Because to create this electricity it is adding extra 'load' to spin. Thus, slowing down the effectiveness of the fuel per kilometre.
killrsheep in reply to Noodle93Jan 18, 2009. 10:33 PM
I second that simple yet completely correct explanation, bcuz of that you gould need a sort of engaging, disengaging system to activate/deactivate when accelerating/braking plus 4 that size it would probably have to b a non magnetic generator, not to go into much detail its uses electromagnetism adn well it get more complicated from there on thus it is used in modern Eco-friendly cars with "regenerative braking systems" but still present technology offers a very poor cost/benefit factor in these kind of stuff
Noodle93 in reply to killrsheepJan 19, 2009. 1:11 AM
Yes. Now I have the correct terms! "This" energy is not being wasted. We are combusting chemicals into kinetic energy (movement). The kinetic energy is making us move forward (or reverse for that matter). For every reaction we make there is an equal reaction, but it's efficiency is never 100%. If it was 100% we would have perpetual motion, which defies the laws of physics. Now if we did your suggestion, the process would this be: Chemical Energy (fuel burning) to Kinetic Energy (the pistons moving, the wheels turning) to Magnetic Energy (an magnet moving in and out of a coil etc.) to Electrical Energy (electrical charge) The more reactions, the more energy wasted in undesired forms. Whereas kinetic energy is not an undesired form.
qolque says: Dec 14, 2009. 7:26 PM
Glad you boys are experimenting, learning on your own.  There's not much that's revolutionary here, it's essentially the same process as water spinning a turbine/generator in a hydroelectric dam, and sending the power over miles of wire to a home where a circular saw runs.  One motor spinning the other.  The key is you figured it out by yourself!  Experimenting is what moves America forward!  I played with LEGOs myself as a boy, even though they've come a long ways since those years.
So don't let the naysayers and their insults get to ya.  Even if they are right about limited application of this particular trick (DC power loss over wires of any length, no perpetual motion due to friction/heat loss), it doesn't mean there aren't discoveries to be made.  Critics don't invent and they don't get patents either!  They just get frownier and more bitter and sarcastic.
So keep it up with the experimenting!  Thousands of engineers the world over are doing similar work
cantrell8 says: Aug 7, 2009. 11:41 AM
I wonder if this would work with any motor?
sheepborg says: Jul 28, 2009. 7:22 AM
at the fastest I can spin the mindstorm motor it puts out the equivalent of between 2 and 3 AA batteries
sheepborg in reply to sheepborgJul 28, 2009. 1:45 PM
Edit : at normal (slowish) speeds it puts out 1-2 AA batteries worth
joey2542667 says: May 12, 2007. 4:44 PM
what you can do is you can make a much bigger one and use it on a electric car! I should get a padent!
JakeManes in reply to joey2542667Nov 1, 2007. 7:44 PM
the energy created would equal the energy exerted. So its like using a gas generator to power a light to power a solar panel. And its patent. And electric cars have been patented.
But if you dont believe me, do some searching here:
http://www.google.com/patents
wheatstone in reply to JakeManesSep 18, 2008. 1:13 AM
there you go again perpetual energy...it will never be equal. one cannot destroy energy but rather transform it! Your loss is through heat!!!
joey2542667 in reply to wheatstoneSep 18, 2008. 7:40 AM
lol, are you talking to me or Jake?
wheatstone in reply to joey2542667Jun 7, 2009. 4:42 PM
Put a hat on!
joey2542667 in reply to JakeManesNov 2, 2007. 9:25 PM
oh, ok i guess that wouldn't work... Oh well. Hey, should i post some of my office weapons?
wheatstone in reply to joey2542667Jun 7, 2009. 4:44 PM
you too! lol
JakeManes in reply to joey2542667Nov 5, 2007. 10:02 AM
depends if they are already posted.
joey2542667 in reply to JakeManesNov 10, 2007. 8:31 AM
no none of em' are posted. I have two that I can think of but one the ammo is juniper berries
L-A says: May 26, 2009. 1:50 PM
That's an old trick that (if I recall correctly) originated from a japanese lego bot builder, who made walkers you controlled by turning a motor alternatively left and right. It's good for making a steerable car, too.
lucianoabcd says: Oct 11, 2007. 1:02 PM
I tried this with a 3V-motor and I can't get any reading in the multimeter when set to voltage, and only a few microamperes in current mode. The shaft was moving very fast in my trials (I attached it to a wheel on my bike and rode it) and I know that the motor works ok (I mean as a motor), so which do you think the problem is? Can it be the fact that the motor is not a steeper motor? Thanks!
killrsheep in reply to lucianoabcdJan 18, 2009. 10:41 PM
nah its ok if its not a stepper motor as long as it uses magnets to generate the magnetic field inside, it could also be what the guy below me said maybe you are not puting enough rpm's through the axle
rotf101 in reply to lucianoabcdDec 26, 2008. 5:07 PM
i got the same problem with a small 3v generator found in hand-held fans. i attached it to my bike and even at top speed, it put out only about 1v. then i found out that 3v of power from batteries turns the axle far faster than my bike, thus the lower output. the efficiency of the generator can also affect the output. i decided to find myself a 10v generator often found in higher-end r/c cars. it doesn't put out 10v, but it puts out enough to power a bike light.
sooraj619 in reply to rotf101Mar 16, 2009. 8:15 AM
can u say which motor i should buy to generate a 3v
Sandisk1duo says: May 23, 2008. 3:25 PM
wow! those are really efficient motors!
rotf101 in reply to Sandisk1duoDec 26, 2008. 5:00 PM
that's the first thing i noticed!
Sandisk1duo in reply to rotf101Dec 27, 2008. 9:23 AM
too bad that they are around $20 a piece
rotf101 in reply to Sandisk1duoDec 27, 2008. 10:22 PM
oh wow...i think it's better to invest in higher quality RC motors. those 10v things are really nice
Sandisk1duo in reply to rotf101Dec 27, 2008. 11:02 PM
psh... forget your RC motor, go invest in the stock market, it's been going up and down for the past few months
rotf101 in reply to Sandisk1duoDec 28, 2008. 7:31 AM
haha. i have a couple stocks: apple, google, baidu. none of them are looking too pretty since i bought them
1-40 of 97Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
