Lego Gun
84,018
32
86
Published
Introduction: Lego Gun
In this instructable I will share with you my own lego gun design.
Step 1: Bits
For this gun to work you must have the following:
4 4x4
9 blocks with holes
1 small 2
1 12 blobbed slab
1 8x2 slab
1 cube
1 6.3 cm stick
1 dynamic stick holder
2 clips
1 5 holed block
1 stick with blob
pointy blob
Step 2: Muzzle
1. Get the 12 blob slab.
2. Put three holle bricks in a row on the right hand side.
3. Leave a space.
4. then put six more on.
Step 3: Trigger
1.Get the 5 holed block
2.put the plug in th middle
3.then attach to the cube.
Step 4: Attaching the Trigger
1.Put trigger onto left hand side of 12 slab so that th 5 holed block can go in the space between the single hole bricks.
Step 5: Clips Part 1
On the second single holed block attach small two, then infron of that put the 10 blobbed stick.
Step 6: Clips Part 2
First attach the two clips at either end of the ten blobbed stick, then attach the 8x2 between them
Step 7: Rubber Band Hammer
Attach the dynamic stick holder to the stick, then insert the rubber band through the hole.
Step 8: Loading Hammer
Push hammer through back holes (make sure trigger is up), strech both ends into clips
Step 9: Handle
Stack 4x4s in tower then attach at trigger end.
Step 10: Bullet
Attach the pointy blob to the stick with blob
Step 11: Loading
Pull back hammer and gently push down trigger
Step 12: Putting in Bullet
Put bulletinto the end of the barrel
Step 13: Aiming at Target
Aim at a target, If you would like to see my own target design get on to www.pranksters-cookbook.blogspot.com
Step 14: Firing
To fir push trigger down.
Thanks for looking at my instructable I hope you found it useful.
    • Pets Challenge
      Pets Challenge
    • Make it Move Contest
    86 Comments
    What do you mean by "blob"?
    whos the guy in the background?
    yo peeps i kneed a good lego gun and fast put the instructions in my inbox thanks
    hey how is every one . if you have good instructions for a bolt action lego rifle can you please put them in my inbox thanks every one.
     KNEX is so much better although good gun for lego
    this is a good gun for lego! http://www.youtube.com/watch?v=efe9NLZ6_i4
    You just need to find one that fits. Shorter but thicker ones will fire further, but will put more strain on the body. I just realised how late this comment is =b Maybe it'll serve useful for someone else.
    nice. The only is I don't have that much blocks with holes in them
    im making an instrucatble on a simpler gun and its way easyer to make...
    lol block trigger.
    heyy
    i made this its awesome but i moved it around and made it more stronger so it wouldnt fall apart as much
    anyways i think its great cause its really simple to make and doesnt use many parts!
    1 of the best things iv ever seen
    very small but cool
    every time i shoot it, the rod keeps shooting owut of it. oh, and i modified it to look like a cross bow! i called it the BLUE BANSHEE!
    hmmm a lego gun that looks alot and works alot like a knex gun... its a start but look at lego guns on google images and ull find a lego machine gun that u gust need to put a motar on it and it fires something that looks like gum strips lol
    POOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOST IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    umm i dont think so...
