Lego Hard Drive Case Mod
I am a computer geek, age 13. I also like building stuff outta Lego. Now, my two worlds collide.
I made a Lego External USB Hard Drive! Ok, fine, technically, I didn't make it, I just modded the case. The enclosure worked fine, but it was completely SEALED and didn't make a very good heat dissipating case. My original was a Vantec Nexstar CX 3.5" SATA Enclosure. Basically, I took out the SATA-USB logic chip and the frame of the drive and encased it in Lego Bricks. This may not be the best looking design, because my mom doesn't let me have thousands of dollars for mounds of Legos. Oh well, better than nothing!
I also attached a fan to increase air flow, even though there are a lot of holes already. My soldering iron broke and I'm out of solder, so I cant attach the leads for the fan yet. I'm trying to tap the 12v, but the power switch only controls the 5v. So I need to keep looking.
The instructions are not really able to be included because Legos are very versatile and hard to set because we all have different sets, but I'll do what I can to make this easier.
This final has come a long way (3 hours) and a bit of work to turn it into what it is now. Originally, the fan was underneath, but the legs had to be too high. More improvements are to come soon, so keep looking. Advice? Please!
Please rate this instructable!!!!!
Step 1Baseplate
Baseplate
The base has no vent holes in it. It's just a completely flat piece (made up of a series of smaller pieces) where the hard drive will be placed. See the picture for more details. The base plate is made up of pieces adding up to 24x16 Lego units. A small extension is required to stop it from falling out and for the I/O panel. It looks different from the finished edition on the cover because I took it apart to document for this Instructable and the base fell apart, so had to reinforce it, A LOT.
34 comments
Nov 10, 2011. 3:40 AMMatrix-technician says:
To power your fan I would reccomend using a lithium polymer rechargeable battery pack. These are used in high drain devices like r/c helicopters or something that runs a high speed motor. They vary in sizes and pricing but I'm sure you could find a 12 volt one easily enough. I would reccomend getting a slightly higher voltage and use a 12v regulator. This way the battery will stay charged longer and won't work as hard extending it's life.
Apr 18, 2009. 1:22 PMTheKingpin says:
Where did you get the I/O port and all that from? Just from a case?
Apr 19, 2009. 2:51 AMTheKingpin says:
Thanks, I was looking on the internet and all I could find were big converters with also to SATA. But there were immense...
Feb 2, 2011. 6:06 PMMCzone says:
I took apart an old external cd drive, the back part might have an SATA converter plus power supply
Nov 14, 2010. 9:58 AMTSC says:
Sweet! sweet! sweet! sweet! All the do day long!!
Jul 9, 2009. 4:37 PMFagnerFS says:
There's one word to write about the project and your work: AMAZING! I feel sad, because i gave my LEGO pieces to my little cousin. I'm going to his house to stole them back to me! Starting the stealth mission... where's my night google? Oh Jesus, I also gave it to him!
Apr 18, 2009. 1:18 PMTheKingpin says:
Nice Tut!
Mar 26, 2009. 10:37 PMboudyreau says:
Next Project: Build an entire computer case out of LEGOs..................I think I might actually do that. lol
Apr 15, 2009. 9:46 PMzippydaspinhead says:
google's original servers were built from lego cases. It was convenent for them because they were small back then and rapidly expanded so it was easy to adjust the cases acordingly. Then they got huge a built tower/blade servers.
Mar 24, 2009. 9:18 AMNoHighResGames says:
Really great idea. I'm very impressed. As a fellow poor Lego aficionado I can assure you that most of my creations don't come out looking streamlined either...or in less than 5 colors usually, lol. I might think about using this mod myself. Keep it up, genius!
Feb 28, 2009. 1:29 PMMario1 says:
You can find a 12v rail simply by testing the leads with a voltmeter.
Oct 21, 2008. 11:51 PMbeatbft says:
cool mod, but I think you can't get more than 5 volts from USB power, unless you come up with a way to increase DC (which is not an easy feat..) perhaps it would be better to get a 5Volt fan.... Keep the good work, cool case..!
Oct 22, 2008. 1:00 AMfalcotheimpaler says:
Actually, since it's a molex hard drive, the external supply has a +12 and +5v rail,
Feb 20, 2009. 1:18 PMjotism says:
If you dont mind taking the side off ur PC. just use one of the fan plugs for the computers fans if you have any spare, if not, just splice a fan lead and wrap the wires wound it.
Oct 22, 2008. 10:14 AMbeatbft says:
Yeah youre right, so if you got the 12 volts maybe you can change the switch to a double pole to control both 12 and 5v.
Feb 28, 2009. 1:27 PMMario1 says:
I'm 13 too and i have plenty of "electrical parts" that a 30 year old thinkgeek fan would have :D What are your limitations ? I often use all of the stuff i have.... The last time that i used a PIC microcontroller was when my mom had a birthday and i wanted to make her a nice LED dot matrix display :D
Feb 20, 2009. 10:33 AMjotism says:
I don't, Ive got loads of electrical stuff I'll probably never use (lol) and I am 13. If you want any, just ask, or go to the JOT shop in the forums.
Jan 2, 2009. 10:10 PMGorillazMiko says:
If you want the data, you'll have to go through me!! LOL, nice.
Feb 20, 2009. 10:26 AMjotism says:
That is cos windows sucks Ubuntu's emm... orangeness!!! Just like this website is orange.
Feb 20, 2009. 12:47 PMjotism says:
Wat OS r u runnin???
Feb 2, 2009. 10:57 PMblakeredfield says:
Young dude, if you can a) write so well, b) love building things and figuring things out and c) have the understanding of physics necessary to contemplate the dissipation of heat in your system, then don't let anyone keep you out of school! Excellent mod 10/10. Keep em coming!
Jan 20, 2009. 9:00 PMmixadj says:
Dang I didn't pick up my first iron till I was 14. By the way, nice instructable. I think I'm going to have to raid the old Lego bin that's been gathering dust.
Dec 16, 2008. 8:17 PMjschmadeke4life says:
Great write up - I appreciate you taking the time to share this with us!
Oct 22, 2008. 9:39 AMtubbsey88 says:
nice job, i like "dumb" lego projects too. I built my own "iHome" outta legos, so nice work.
Oct 21, 2008. 8:26 PMabadfart says:
woo Legos
Oct 19, 2008. 7:57 PMfrollard says:
For a 13-year-old you have better writing skills than most adults I know :) Fun project!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:LemonSlice
