Lego Hidden Blade (like the One From Assassin's Creed)
32,265
14
26
Posted in PlayLego
Introduction: Lego Hidden Blade (like the One From Assassin's Creed)
I have a power point on a hidden blade i made from lego. It goes step by step. Its pretty simple, but watch out. Everytime u load it, make sure u push the blade into the holder, or u may get a hidden blade launcher!!
    • Slow Cooker Challenge
    • Outdoor Fitness Challenge
    • Casting Contest
      Casting Contest
    26 Comments
    http://youtu.be/wYfzQ0UOvLM
    Here. I hope this helps! :D
    isn't a hidden blade suposed to be hidden
    here is my i add phantom blade :-)
    Thank you, most of the YouTube videos containing a tutorial on how to make what is shown above are mostly tutorials that have... Uncommon Lego pieces. When I constructed it, I kinda found it a bit small for my hand ( Gods Hand jokes ) so obviously I made it alot fatter and instead of a rubber band. I used a lace material and made it have a flex motion when ejecting the blade out.
    Great Tutorial, thanks and keep it up!
    Cheers,
    thank you ill cheak it out
    how does it lock in place i dont get it and how does it eject also can you just explain to me how it workks too
    See the 0 degree connector at the back of the device (at the bottom of the picture)? It connects to the axle that goes down the middle. At the point in which the axle meets the connector, there is a little bit of lego sticking out. This catches on to the plate. To eject it, the connector is pressed down, releasing it from the plate. I'll see if I can make a vid on it. It's hard to describe. :D
    I wanna make this but i dont have the lego parts
    ive made my own lego blade using a comb and a belt ill tell you how to make it if you msg me back
    How to you lock it in place ready to be thrusted out?
    Good question. The rubber band is positioned so that it pushes the shaft forward and a little up. The 0degree connector has a small ledge which catches on the 4x1 plate going across (like in the pic).
    it's a pretty good idea but you need to make it longer and retractable so you can move the pen in and out
    dude
    for one, it isnt even a blade, its a friggin pen
    and for two, its not connected to your wrist
    i wish i could find a good but cheap switch blade build
    but i do give you credit for being cheap and creative
    and dont think of me as a mean person for critisizing your build, im just expressing my opinion
    how does the blade point out? i'v done all of it.
    but the blade doesn't come out? why not.
    That's strange. Try tightening pieces and jiggling things around. Sorry I have no direct solution :(
    I couldn't make one.But how can i do that?
    I'm sorry. What do you mean? What do you want to do?
    i made my own lego hidden blade and it's mechanism uses a spring and i locks in and out after just pushing a button
    That's an idea to try the next time! Thanks.
