3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lego Microtome
Lego Microtome
A what?
A microtome is a machine which cuts (usu.) biological specimens into very thin sections. The sections are typically mounted on microscope-slides.
This was an idea I had, I did it, and I've demonstrated it with garlic
It creates slices 250 microns thick*
*calculated
If anyone is actually thinking of building one of these see the last step. You can also PM me if you need more
L
Step 1Construction: base and mount runners
  • last photo ←
The specimen sits on a platform which is cranked forwards by gears. The mounting plate is driven by a rack and pinion mechanism geared very low from a hand crank, such that it moves .25mm with each turn of the handle. The platform rests on the red smooth-faced strips, which were lubricated with Johnson's Baby Oil (paraffin).
These images show the base of the device and the red runners for the specimen platform, also the final drive to the rack.
59 comments
1-40 of 59next »
Apr 6, 2010. 8:51 AMPunkguyta says:
 Impressive lemonie! Good work
Apr 6, 2010. 12:17 PMPunkguyta says:
 Ever since I was a kid I have been dying to get my hands on one of those lego mindstorm robotics kits (I've played/programmed with them before, they're a hoot!), but alas never have as they originally cost over $350!!!!
Do you have any good ideas for implementing something similar with regular lego? Like how would I go about making a robot/remote control car out of plain legos? I have a giant blue tub of lego from when I was a kid, and I'm sure super-glued together would make one hell of a sturdy frame if designed right?
What kind of software do you use to design lego builds? I know there is software that basically lets you build something on the computer first, before you try it, so you can make sure it will work.
Sep 2, 2011. 5:21 PMForgerOfPie says:
If you want something a bit cheaper, maybe you should try something like Arduino. It's not Lego-manufactured, but I've seen plenty of Arduinos users that have hacked lego Technic motors to control them. Mail me if you want resources.
And come on, this is INSTRUCTABLES.COM! I know you can find SOMETHING on here.
May 20, 2011. 10:33 AMCheezpaper says:
Put a bug in there. Watch the yellow goo gush out.
Nov 24, 2010. 2:37 AMmichaelgohjs says:
cool... btw can u please tell me the gear ratio u used between the blade crank and the shaft to move the garlic (i m familiar with lego parts)
Mar 24, 2010. 6:27 AMmichaelgohjs says:
thx alot .. its gona take alot alot of gears and worm gears
Jan 19, 2010. 6:23 PMtotos says:
superb!
I WANT ONE!!!
Aug 23, 2009. 6:27 AMdissonum says:
Excellent! As a histotech, I was shocked (SHOCKED!) to see the word "microtome" on the website. Very awesome.
Aug 19, 2009. 7:43 AMRobert L says:
Thats Really cool.
Aug 15, 2009. 1:45 PMastrong0 says:
dude you could add a motor to it and make it automated (to a degree)!!
Aug 2, 2009. 12:35 PMEl Mano says:
That's awesome!
Jul 21, 2009. 10:34 AMscoochmaroo says:
Looks like it could easily be automated? I mean if I were using it to cut garlic and not samples. I have way more garlic around.
Jul 21, 2009. 11:47 AMscoochmaroo says:
totally! I finally invested in a mandolin. I'm going to throw out those chopper things. They look so promising on tv.
Aug 1, 2009. 2:35 PMfusion says:
i wanted to get a mandolin as well, times being what they are and realizing that i only needed it for very thin things, i got the titan peeler with the slicing attachment. works great. plus the julienne. it was a good substitute for the 50$ truffle slicer i was going to get. i'm probably going to do this for dehydrating truffles tho.
Jul 22, 2009. 6:29 AMRotten194 says:
Slap Chop! You're gonna slap all your troubles away with the Slap Chop!
Jul 21, 2009. 12:23 PMcorey_caffeine says:
yes but didn't you love his nuts?
Jul 23, 2009. 2:51 PMmadhops0620 says:
Jul 21, 2009. 1:58 PMconrad2468 says:
Itll dry your sweaters............wine coffee cola.......
Jul 29, 2009. 6:21 AMswimmer95 says:
its to hard to see the pictures!!!! and i want to build it!!
Jul 30, 2009. 5:45 AMswimmer95 says:
well i got about half way and then i couldnt finish because i did something wrong early
Jul 29, 2009. 8:23 AMswimmer95 says:
how do u get the left rail on!!!!! help me!!!
Jul 24, 2009. 6:48 PMReCreate says:
Wow, 200 Microns O_o
Jul 25, 2009. 9:41 AMReCreate says:
about 200 Microns...
Jul 21, 2009. 8:53 PMDr.Paj says:
I've made one of these before. I only used a spool from sewing string, and a eyelet with a long screw (for hanging things such as swings etc.) and just screw it into the circular opening of the spool. You then would place the object you are cutting (carrot, union, human finger, etc) inside the spools hole. So when u twist the eyelet clockwise it slowly moves the object you are cutting forward. Then cut what protrudes from the end of the spool with a razor blade. This way is way less cool, and its a little more dangerous because you have to handle the blade by hand, but its much faster, and it doesn't require Legos.
Jul 24, 2009. 10:47 AMDr.Paj says:
Anything that fits in the spool that is easily cut by the razor blade. Mainly vegetables so you could look at the cell structure under the microscope.
Jul 22, 2009. 9:11 PMluvit says:
i was looking for instructions for a guillotine...
Jul 23, 2009. 2:42 AMFashim says:
Why?
Jul 23, 2009. 3:32 PMluvit says:
to cut cigars?
1-40 of 59next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
315
Author:lemonie
I'm an experimentalist, a scientist and I have a tendency to do things just for the sake of doing them, or to find out what they're like. I don't like stuff that sucks, please show me something that...
more »
