3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lego Nxt "Secrets": Light Sensor Music/Wand
Step 2Build the shaft/wand [People doing Only the Required:Skip this step]
Stick the Various connectors in like Image 1, Then Put the Light Sensor on the two connectors sticking out from the side at the top, and then the NXT brick onto the Bottom two sticking out from the side at the bottom. Attach cable from light sensor to Port 3.
Please note that I messed up with the photos while rebuilding it, if you attach the NXT brick using the studs from Image 1, You will NEED to use a long cable, Image 2 uses a Medium cable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bigbrainkid
