Lego Nxt working with no batteries
A couple wires, a diode, a 5v to 9v usb adapter, and you are in business. The reason I did this was to make a fish feeder work for at least a week. I was going away and didn't want anyone to be burden with fish feeding.
Supplies:
Usb cable for NXT brick (included in Mindstorm kit)
A 2 amp diode ( thank you Lan01)
Tools:
soldering iron and solder
wire (small size from radio shack)
Phillips screw driver
wire cutters and needle nose pliers
Step 1Opening NXT
Opening NXT
Take out batteries and the four small screws in each corner (Not now but in a future step you will need to pay attention to the little black button in the low middle of the picture). Turn over brick and pull on the white face plate. Might be a little tough but comes straight out.
The board is attached to the screen by 3 items. 1.) Two screws one on each side of the screen. 2.) The 10 solder spots. If you just pull up from that spot it should come right out but be careful because the side with the speaker has (3.) 2 wires that do not separate. So fold the screen over on its face. You can put something soft down so as if not to scratch it (as you can see in the third picture I did not. Nothing was scratched but better safe than sorry).
23 comments
Feb 13, 2007. 9:55 PMIan01 says:
1. NXT motors can draw up to 2A each when stalled. Make sure your diodes can handle it. 2. Can you still use the USB port for downloading programs?
Jan 11, 2009. 7:03 PMraykholo says:
speaking of the motors -- they are described as servos, but are are able to make full rotations like if i wanted to use them as wheels am i wrong ??? since the wiki says servos can only make small rotations and their primary use is stuff like robot arms... with only small turns here and there
Aug 23, 2009. 3:59 PMMusicman41 says:
The motors are basicly regular dc motors with a rotation sensor attached. You can program it to do unlimited full rotation, or to rotate by parts of a degree. Wiki is wrong in the fact that it can only do small turns. I know this because I won and use an NXT with its motors.'
Aug 31, 2009. 5:01 AMraykholo says:
i think you misunderstood. I was talking about the nxt wiki, saying that the motors are servos. I know they can do full turns, i have an nxt too. just sayin that the motors are not servos, while the nxt wiki describes them as such...
Feb 14, 2007. 12:02 AMLasVegas says:
USB only supplies 500mA at 5V. This means the 9V adapter probably supplies about 250mA (a quarter amp). The diodes have nothing to do with it. I wouldn't suggest trying to drive very much directly from the USB supply. Only 1 diode on the positive line is needed to prevent draining the batteries through the supply. The second diode on the ground line is redundant.
Feb 14, 2007. 3:43 PMLasVegas says:
As long as your motor doesn't stall, you may only be pulling under a quarter amp. One plus to this design is that you're using a third party 5v-9v adapter. The adapter is likely already current limiting, protecting the USB port. This might cause your feeder to run a little slow, but the computer's port is protected.
Dec 15, 2007. 8:55 PMXpyd3r says:
Big Question I'm trying to figure out how to do a similar idea. I want to be able to program and reprogram to fix bugs without constantly wearing down my limited supply of batteries. so i wanted a transformer to basically do the same job as the batteries did, I had a talk with my friend and he said a 9v 350mA would probably be fine, but the rechargeable battery from lego is 7.4v 1400mA so I'm kinda confused, help or suggestions?
Sep 4, 2009. 11:37 PMterrapinlogo says:
the rechargable battery is only 7.4v but the nxt runs better of alkaline batterys as they supply 9v. the only reason that the rechargeables supply 7.4v is because each cell can only supply 1.2v vers 1.5 for the alkaline batterys
Aug 23, 2009. 4:01 PMMusicman41 says:
Couldn't you just attach the wires to the two termanals outside the nxt casing (where the batteries usually touch) rather than opening the expensive brick?
Apr 6, 2009. 12:32 AMkerotamama says:
I've been looking to replace the battery with another energy source. Using the usb is ok, but I don't feel like soldering and opening up the nxt. Can we basically use an AC adapter to power it, i used my multimeter to test the current. It shows up around 125 mA. So can I just buy a 9V and 125 mA AC adapter to do it?
Mar 9, 2009. 9:25 PMSpeedmite says:
Why not make a bunch of potato batteries?If I remember right from my 2nd grade science project forever ago, 2 potato halves with a zinc plated door hinge with a thick piece of copper wire made close to 1.5 volts or 1 volt. They stay at the same voltage for weeks. I only tested it for 2 weeks. that would work too. amps were a problem though... And then there was the one minute-20 volt battery. That was fun..... Jk about the potatoes. It would work but, yours seems more effective and cheaper than that potato battery stuff.
Jan 11, 2009. 7:01 PMraykholo says:
due to the high price of the nxt, i would rather not open it up there is a 50$ rechargeable battery for it, or you could just wire it up with rechargeable batteries -- this does involve modding it, but the circuit board is untouched
Dec 4, 2007. 5:32 AM04bobby1 says:
You should post some Lego Mindstorm models i am going to soon when i get my set for Christmas
May 15, 2008. 6:37 AMjedi pen-gui-n says:
Feb 13, 2008. 1:27 PMthe gizmoman says:
i finally got a Lego mindstorm & so far Ive built a cool car & a machine gun
Feb 14, 2007. 1:10 PMbackcountry says:
I don't see the connection between this instructable and it's purpose, fish feeding. Do you have a fish feeder that runs off a NXT brick? I take a simpler approach to feeding fish when I'm on vacation. I purchase a 10-day food block and drop it into the tank - works every time and not affected by power outages, etc. But your approach looks like more fun.
Nov 29, 2007. 5:40 AMjeffconnelly says:
I think i've seen your fish feeder on either NXTLog or in a SERVO Mag... Do you know which?
Dec 3, 2007. 4:29 AMjeffconnelly says:
Pretty Sure
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:richiehops
