Supplies:
Usb cable for NXT brick (included in Mindstorm kit)
5v to 9v usb adapter
A 2 amp diode ( thank you Lan01)
Tools:
soldering iron and solder
wire (small size from radio shack)
Phillips screw driver
wire cutters and needle nose pliers
Remove these ads by
Signing UpStep 1Opening NXT
The board is attached to the screen by 3 items. 1.) Two screws one on each side of the screen. 2.) The 10 solder spots. If you just pull up from that spot it should come right out but be careful because the side with the speaker has (3.) 2 wires that do not separate. So fold the screen over on its face. You can put something soft down so as if not to scratch it (as you can see in the third picture I did not. Nothing was scratched but better safe than sorry).
23
comments
Add Comment
LasVegas
says:
LasVegas
says:
terrapinlogo
says:
Add Comment
