Step 2Inside Case
Next take two wires cut them decently long and have the diode ready. If you can see from the picture I wedged a battery in between the board and battery pack to give me room to solder.
The bottom of the usb port has 4 major solder points. The two closest to the larger side is the power.
In the picture the wire with the knot is the + (do not put a knot in the wire but a black mark because you will be routing these two wires into a small hole).
After you solder the two points run the wires into one of the screw holes(same screw holes that hold the face plate to the battery pack) to the side of the board that has the screen on it .
Add Comment
