Introduction: Lego Raspberry Pi Case (for a & B Model)
Before getting my Raspberry Pi B model in the mail I made up my mind to make a case for it (pretty much a necessity). After looking at many very cool designs, I discovered a girl named Biz over at raspberrypi.org had made a case out of Lego and had the proper x & y dimensions, 9 x 13. So I ran the “Lego Digital Design” (LDD) software I had installed quite awhile ago, and plugged away.
LDD is essential a CAD program from Lego that uses the Lego pieces in a virtual build area, it is free and very easy to use. It contains almost all the pieces EVER made by Lego, in ALL the colours available though some recent ones are not in the database. i.e. some new Star Wars cockpits.
So after you have finished what ever you design virtually you can then order the pieces to build from Lego itself (most older pieces are not available) or from a site such as Bricklink.
Bricklink is basically a Lego version of ebay. As of 2012 there are 222,835 registered members from 144 countries currently registered on BrickLink. It has thousands of Local and World Wide online stores with their own inventories that let you browse, shop or request pieces and then order the pieces you need and then they are mailed to you. What more could you ask for.
I am sure there are other sites like Bricklink, but I have found it has some online stores near my house that have all I could want in Lego at great prices and delivery rates. I have even started shopping for harder to find pieces from a shop in the Czech Republic that is great. Anyway… the case.
Instead of trying to describe each step I just took screenshots of the build in LDD.
I will also include the .lxf file so you can download it and run it in the LDD program so you can change things or design your own. Enjoy.
Step 1: Complete Parts List
2 - 1x1 Brick #3005 (Clear)
2 - 1x2 Brick #3004 (Clear)
1 - 1x1 Round Plate #6141
3 - 1x1 Plate #3024
7 - 1x2 Plates #3023
4 - 1x3 Plates #3623
9 - 1x4 Plates #3710
10 - 1x8 Plates #3460
1 - 1x12 Plate #60479
8 - 3x3 Plates, ¼ Circle #30357
4 – 4x6 Plates #3032
7 - 4x8 Plates #3035
4 - 6x6 Plates w/ Bow #6003
3 - 1x1 Technic Brick #6541
9 - 1x2 Technic Brick #32000
(The Technic Brick #3700 has 1 hole instead of 2 if you like)
1 - 1x8 Technic Brick #3702
1 - 1x10 Technic Brick #2730
2 - 1x3x2 Left Doors #3189
1 - 1x3x2 Right Door #3188
2 - 1x3 Right Doors #3821
1 - Megaphone #4349
A couple of optional parts used in Step 7
1 - 1x2 Flat Plate #3069 (Clear)
or 2x2 Flat Plate #3068 (Clear)
Step 2:
Step 3: The Base
(All Parts Black unless noted).
Update: I have changed the LDD files to another site as Minus is not cooperating.
Lego Digital Design .lxf file of the project and 4 other Cases I was working on. Stored on uploaded.net.
I have colour coded the parts that are being used in each Level,
they will be changed to the cases final colour (mostly Black) as the build progresses.
Each Level builds on the Previous Level.
Sorry for the Black backgrounds in the pictures, they were grey until I uploaded to my library.
Level 1: Base Lego Part # (if you are looking on Bricklink they come in VERY handy.
3 - 4x8 Plates #3035
3 – 1x4 Plates #3710
1 – 1x8 Plate #3460
1 - 1x1 Plate #3024
Level 2: Base 2
2 – 1x4 Plates #3710
1 – 1x12 Plate #60479
1 – 1x1 Plate #3024
Step 4: The Footers
Level 3: Footer
3 - 1x8 Plates #3460
1 – 1x4 Plate #3710
4 – 1x2 Plates #3023
Ignore the 1x3 Plate in the image for Level 3 please.
Level 4: Footer 2
2 - 1x8 Plates #3460
1 - 1x4 Plate #3710
2 - 1x3 Plates #3623
2 - 1x2 Plates #3023
1 - 1x1 Plate #3024
Step 5: The Walls and Doors
It looked really cool in LDD.
Level 5: Wall
7 - 1x2 Technic Brick #32000
1 - 1x1 Technic Brick #6541
1 - 1x2 Brick #3004 Clear
1 - 1x1 Brick #3005 Clear
1 – Megaphone #4349
Level 6: Wall 2
2 - 1x2 Technic Brick #32000
2 - 1x1 Technic Brick #6541
1 – 1x1 Round Plate #6141
2 – 1x3x2 Left Doors #3189 Blue
1 – 1x3x2 Right Door #3188 Blue
2 – 1x3 Right Doors #3821 1 Black, 1 Blue
Step 6: Header
Level 7: Header
4 - 1x8 Plates #3460
1 - 1x2 Plate #3023
Step 7: The Roof
Level 8: Roof
2 – 6x6 Plates w/ Bow #6003
2 – 3x3 Plates, ¼ Circle #30357
Level 9: Roof Trim
6 – 3x3 Plates, ¼ Circle #30357 4 Dark Blue, 2 Black
Step 8: Finished Product and Observations
Most Lego pieces are based on even numbers (at least the ones I wanted). The fact the outline was 9x13 in Lego profile made it hard to get a strong base which is why there are so many Plate levels.
You may find your RaspPi board fits tighter or more loose than mine. I put a flat 2x2 clear Plate* (see below) up on edge in the corner were the clear pieces are, squished between the wall and the board to stop the board moving when I put the SD card in or removed it. That is also the reason I used the Megaphone, to separate the USB ports and Ethernet port and hold the board in place. I had also had small 1x1 Plate pieces underneath to hold Board off the base but discovered they were not needed.
*1 – 1x2 Flat Plate #3069 Clear
or 2x2 Flat Plate #3068 Clear
Really put a lot of time in this and am really looking forward to using my Raspberry Pi. Hope this is useful.
Thanks to Acacia and Sprocket for their help.
