3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lego USB Charger
Step 2The electronics
The electronics
The 3 parts needed for this step are:
- Short lego wire, cut the block piece off one end and strip about a centimeter of the wire off
- +5V Fixed-Voltage Regulator 7805
- Female usb port
Plug the lego wire onto the motor as shown in the photos, test out which wire is positive by connecting the stripped wires to a multimeter and cranking the motor. Wire the positive end to pin 1 (input) on the voltage regulator. Wire pin 3 (output) to pin 1 on the usb port (if staring into the socket while the contacts on the inside are facing down, pin one is the farthest to the left). Wire pin 4 on the usb socket, and pin 2 on the voltage regulator to the negative lego wire.
7 comments
Jul 16, 2010. 6:35 PMBrickman says:
do you know which side of the lego wire is positive and negative? O and Radioshack carries the 7805 voltage regulator, i got it pretty easily.
Aug 6, 2011. 5:14 AMdannystaple says:
Since the motor can be turned either way, I think the polarity can change. The next question is would this still work if a tiny rectifier bridge was added - like this one - http://www.squidoo.com/freeforming-a-diode-h-bridge. It would drop a few volts mind...
Aug 18, 2009. 5:16 PMTarzanJr says:
no lol
Jun 25, 2009. 7:07 PMwsx587 says:
do you need a voltage regulator
Feb 11, 2008. 6:48 PMOtaconmgs says:
Where did you get the voltage regulator?
Jun 19, 2009. 9:15 AMmerijnvw says:
just search for voltage regulator 7805 and order it
May 3, 2009. 5:05 PMpballpro44 says:
can i use a different voltage regulator
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
