Remove these ads by
Signing UpStep 1Creating The Case
The four parts were stuck together using super glue and a steady hand.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
Images attached, sorry for the bad quality. They are made with my phone.
(Sorry the pictures seem worse quality than it is on my computer.)
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/I-Made-It-Challenge-Is-Back-Win-A-Pro-Membership/
I'm Hungry here in ISS, It's sooooo boring!!!!!!!! Advice? :[ + }:( = }:[
there is just no way when I can get the same size(in GB) for a whole lot cheaper at Walmart or Office Max.
Don't get me wrong, I think they are way cool & I like them...I just don't like them THAT much.
Try and find wafer usb sticks as they take less effort to insert in to one of the bricks. I used a 2X4 for the stick and a 2X2 for the cap then simply inverted flat 2x4 and 2x2 for the bottom coverings.
If you use plumbing goop it takes 48hours to fully harden but holds like crazy. Then if you use some small super magnets (rare earth) and insert them in to the inside of the lego casing while the glue dries; you get a cap that holds itself on.
I attached the pic with dimes simply to show the magnet placements. Also I would suggest you make a template or use slow speed on the dremel to avoid making a bumpy line on your holes.
you could loose all your memory, the Hard drive could turn into a large paperweight,...the CPU could go south permanently....there is all kinds of things hat can go wrong having magnets near the computer.
See some of the other comments below too. :)
microdots
