3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lego USB Stick
Lego USB Stick
Creating a case out of Lego to house a USB memory stick. This has been done before but I haven't seen it done like this :)
Step 1Creating The Case
Creating The Case
Because my memory stick was quite large (in dimensions, not in storage capacity) I had to create a 6x3 Lego brick. I chopped a 4x2 and a 2x2 brick in half using a pen knife and another brick as a guide, the pliers on the same penknife were then used to remove the inner bits of the bricks and then the knife was used once again to remove the sides. Another 4x2 and a 2x2 brick were then used to create the case.
The four parts were stuck together using super glue and a steady hand.
486 comments
1-40 of 486next »
Apr 15, 2007. 2:37 PMkendrick90 says:
This is what mine ended up looking like, it has a regular lego bottom too so you can build around it.
Apr 15, 2007. 2:43 PMkendrick90 says:
Pictures:
Jun 24, 2007. 9:36 AMfreewheeler says:
check out it:i made a case for my sandisk cruzer with this smint container.just as you would use it normally for mints,here you push it in to make the jack come out the other end,and i removed the spring that manes it close properly.
Jun 28, 2007. 2:57 PMdannydutton says:
Ohhhhhh, so thats what a minifun is. I saw a bunch of them at Wegman's and I had no clue what it was. I thought it was some new type of storage (not a USB).
Oct 19, 2011. 5:14 AMcornflaker says:
Hey I have an old 512mb one of those, did you know that if you pull the metal thing off (the usb connector part) you can get a really small flash drive? it's kinda hard to get out though and you need to jam a bit of paper in behind it cause it's too thin...
Mar 14, 2008. 1:32 PMscowmoo says:
Hey, Would you mind giving me a sort of "Mini Instructable" on how to make your version? I can't figure it out :(
Mar 16, 2008. 2:04 AMindrog says:
Hello, I was inspired by this instructable and decided to make a Lego usb "BLOCK" :) The stick is a Sandisk 4 GB drive, and this model was like a retractable one, and IT FITS PERFECT inside of lego bricks, but I still had to throw some leather strips in so it didnt stay in the computer when I try to remove it ;-} 1.Here are the pieces I used, and also a pic of me modifying the piece... 2.Here are the finished pieces when chip is ready to use (NO GLUE OR CUT PIECES, all natural legos surrounding the drive) 3.Drive plugged in and lit up :) 4.Drive plugged in and lit up :) 5.My fav new lego creation (carrying precious cargo :) this brick is kinda big for a usb port, but it had to be that way because I just built with legos around the chip until it was coverd in legos... Indrog
Mar 16, 2008. 10:36 AMkendrick90 says:
I used two 4X2 bricks and a 4X4 flat plate. I hollowed out the insides of the blue bricks. I also cut off some of the pegs that were sticking up on the bottom grey piece so the usb drive would sit just on top of the base. I cut off a layer from the bottoms of the two blue bricks so that when I put the blue ones on the grey one they were the standard lego height. I cut out a spot on the side to let the usb part stick out. I didn't have any silicon so i used hot glue instead. I just filled up the entire inside with hot glue, stuck the drive in and squished all the pieces together. I don't know if the hot glue is bad for the drive like some people have suggested. I only used this drive to store a few games on and rarely used it but it does still work. Also this usb drive is shaped weird, it came with the piece shown here which plugs into another piece with a standard looking plug. Also it has no lights so i didn't have to worry about making anything clear.
Apr 13, 2008. 11:23 AMjoozey says:
Here is my result :) Thanks for this Instructable!
May 1, 2008. 3:16 PMtonye says:
Here's mine. Notice that one of the bricks is clear/red. That makes the little light on the USB drive visible. Thanks!
Aug 15, 2009. 9:04 AMPresident.Nulagi says:
I saw this, and though it was amazing. However, I think its a bit too bulky. I present my attempt- A six-stud blue brick with black base and a matching 2 stud cap (slides on and off perfectly!). A keyring is fitted, and a blue led shines as a stud at the rear. - I hope this gives inspiration to all of you wanting to try this build!
Nov 16, 2009. 1:22 PMneivadan says:
say how do u build this?
May 14, 2010. 8:52 AMGanoderma says:
 I made one also, just put a thin plate below it so it can still be used in lego buildings (even though it will probably never be used for that)
Images attached, sorry for the bad quality. They are made with my phone.
May 14, 2010. 8:56 AMGanoderma says:
 Forgot to say, the white bit in the cap is from my G19 keyboard. It fits nicely over the USB connection without damaging it (it's silicone/rubber like) and it stays in place. That's how the cap stays on without problems and no magnets or some kind of click system.
Jun 12, 2010. 11:12 AMwout smeets says:
my usb stick
Jul 7, 2010. 10:59 AMgogglepoofs says:
do u think i could pu the original cap inside the end piece? no magnets or whatever
Jul 7, 2010. 11:08 AMGanoderma says:
Depends on the cap really. If the cap clicks on the casing, it won't be much help. However, if the cap stays on by friction on the usb connector it will work (providing your cap is small enough to fit in the lego block of your choice)
Jul 7, 2010. 3:45 PMgogglepoofs says:
thank u
Jul 19, 2010. 9:48 PMHeyJD says:
Thanks. I made one my self. It took a whole day... But it was worth it!
(Sorry the pictures seem worse quality than it is on my computer.)
Jul 22, 2010. 8:49 AMfrenzy says:
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/I-Made-It-Challenge-Is-Back-Win-A-Pro-Membership/
Mar 12, 2012. 8:30 AMTeddybear8 says:
sorry pic to big P.S. Still genious? How do you spell it? some1 please answer!!!!!!!!???!?!!??!?!!?
Mar 12, 2012. 8:28 AMTeddybear8 says:
ths thg is frekn' awesome, Luv water falls/ blue 1s ;)
I'm Hungry here in ISS, It's sooooo boring!!!!!!!! Advice? :[ + }:( = }:[
Mar 10, 2012. 11:43 AMmonsterlego says:
MIne.
Mar 3, 2012. 2:51 PMjjone538 says:
I Rcommend Saving your data on your usb onto your computer before you do it
Jan 8, 2012. 11:00 PMSIRJAMES09 says:
these are nice toys, but there is no way I would ever pay $39 for a 4GB usb....let alone $69 for a 16GB...
there is just no way when I can get the same size(in GB) for a whole lot cheaper at Walmart or Office Max.
Don't get me wrong, I think they are way cool & I like them...I just don't like them THAT much.
Jan 8, 2012. 11:17 PMSIRJAMES09 says:
what about using a Dremel tool to cut /sand/file/etc...? would that not be safer??
Mar 13, 2010. 11:30 PMBanaczech says:
I loved this idea - nerds n lego! As a nerd I have advice.
Try and find wafer usb sticks as they take less effort to insert in to one of the bricks. I used a 2X4 for the stick and a 2X2 for the cap then simply inverted flat 2x4 and 2x2 for the bottom coverings.
If you use plumbing goop it takes 48hours to fully harden but holds like crazy. Then if you use some small super magnets (rare earth) and insert them in to the inside of the lego casing while the glue dries; you get a cap that holds itself on.
I attached the pic with dimes simply to show the magnet placements. Also I would suggest you make a template or use slow speed on the dremel to avoid making a bumpy line on your holes.
Jan 8, 2012. 11:12 PMSIRJAMES09 says:
problem is, you DON'T want magnets anywhere near a computer...it will mess it up.
you could loose all your memory, the Hard drive could turn into a large paperweight,...the CPU could go south permanently....there is all kinds of things hat can go wrong having magnets near the computer.
Dec 25, 2010. 11:12 AMbattlebotbob says:
Sounds like fun BUT magnets might erase any credit cards or hotel room keys you keep in the same pocket or purse. I used to keep a couple of magnets on my keys to play with, but when i traveled i had to go to the front desk often to get my room card re-done, until i figured it out. When they go to RFID that might stop the problem.
Nov 10, 2010. 8:07 PMbigferret says:
I have worked on, in and around computers for over three decades. It has been my "sacred duty" to keep magnets away from data storage devices. As this may apply to a laptop, closing the laptop would also imperil the display screen as it is rendered closer to the magnet. Am I just imagining this?
Nov 14, 2010. 6:51 AMmarcoceppi says:
For those with high fears of magnets you could place the rare earth magnet in the lid only, leaving a metal of some kind on the actual stick portion. Thereby satisfying the fear of magnets by computers while still retaining a functional cap.
Jan 8, 2012. 11:13 PMSIRJAMES09 says:
this is true...but I still wouldn't do it...my data is too valuable to me.
Nov 10, 2010. 11:42 PMBanaczech says:
A magnet won't have any effect on an LCD screen. They style used is also to low power to effect change on a drive in the machine. You'll find there are actually a lot of companies making sticks in this fashion. There are bamboo, silicone, metal and plastic cased drives being produced with magnetic lids.
See some of the other comments below too. :)
Feb 23, 2011. 7:39 AMJedrokivich says:
I heard that some types of silicon can dissolve the solder on the stick, so be careful.
Mar 25, 2010. 1:22 PMmikeeve says:
And a fun project becomes even more fun. Thanks!
Apr 4, 2010. 6:24 PMprodo123 says:
Thank god the magnet doesn't wipe the drive out like it would on a hard drive.
Apr 18, 2010. 10:08 AMkcls says:
If you inserted that into a laptop, at least on my laptop, it would be INCREDIBLY close to the screen. That would be bad.
microdots
May 10, 2010. 1:56 PMjoeofloath says:
LCD screens aren't affected by magnetism. It's only CRT's that are. Of course, on some laptops the hard drive is near the USB slots, that WOULD be bad.
May 10, 2010. 2:21 PMBanaczech says:
Additionally the power ofthe magnet isn't enough to through off the drive- unless you left it in there 24/7
1-40 of 486next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:ianhampton
