Lego USB Stick
Step 3Securing the stick
Securing the stick
I stuck an offcut of one of the bricks at the bottom of the case as I found this made the stick sit at the right height. I then packed the whole thing full of clear silicone to made it stronger and reduce any movement from the stick.
Clear silicone was important as it still allows light to shine through.
20 comments
Jan 3, 2010. 2:57 PMphysicsguybri says:
By encasing the electronics in RTV and th elike you have pretty much secured its heat death. There is a reason why air gaps and open volumes are designed into electronic enclosures.  Memory sticks do get hot and need to vent. Sorry for the buzz-kill folks but thems the facts.  It would be less problematic to have secured it at the corners in some fashion so that ALL of the electronics (IC especially) were still open to the air.
Dec 12, 2011. 2:57 PMchardlz13 says:
I made mine with a hole in the front larger than the USB and encased it using friction alone and just a little glue on the sides to keep it from shifting. Hasn't crashed yet and it's been about 4 or so months with constant use
Jul 31, 2011. 8:39 AMtuskawilla says:
This is what I was fearing in doing this, a lot of tutorials have encased the pcb in glue or whatever, I figure this would kill it with either conductance of some sort or heat death.
otherwise, I love the Lego idea. as I wear my usb on a lanyard, probably be nice to have a hole at the back end for a loop to attach to a key chain or whatever.
Apr 8, 2007. 11:42 AMthe fat hobbit says:
there are actually legos that are translucent and surprisingly they coma in a wide array of colors can this work with megablcoks?
May 25, 2009. 1:45 PMieightu says:
what do you think?
Dec 29, 2010. 10:16 AMValeil says:
nope, probably not.
Jun 21, 2010. 10:03 AMTauman says:
Does anyone know if using E6000 would work? Because me and a friend want to test it out.
Jun 4, 2009. 4:23 PMsweetpea7 says:
I don't have scilicon. Could I use a hot glue gun instead?
Aug 2, 2009. 7:32 PMChromatica says:
that would be fine just make sure the glue isn't to hot or it will melt some of the plastic
Apr 5, 2009. 3:29 PMtapiocapudding says:
Why didn't you just make the notch deeper so that the PCB sits lower in the case and then re-attach the bottom of the original brick?
May 27, 2009. 10:22 AMKasm279 says:
the brick has fin-like things in it, so there would be no bottom ;)
Nov 13, 2008. 3:45 PMu_opo says:
so I know that zoozie just asked this kinda, but I wanted to make sure that it is right. The silicone wont mess up the current?
Mar 31, 2009. 10:33 PMwax54 says:
no it is pretty rubbery and plastic so no conduction
Dec 11, 2008. 10:48 AMwax54 says:
Will hot glue work I don't know were to find clear silicone.
Mar 29, 2009. 8:40 PMlamech08 says:
you can find silicon at any hardware store in the plumbing section.
Dec 15, 2008. 3:11 AMkiwiowl says:
Yes hot glue sould work but heat and electronics don't always go together so be careful. Silicone on the other hand is cheap and available at all hardware suppliers. It's the sort of rubbery stuff they use to seal around bathroom units etc. Get friendly with silicone and you'll find many more uses for this stuff - and it comes in many more colours than hot glue.
Mar 25, 2009. 2:20 PMwax54 says:
where do i find silicone
Mar 27, 2009. 9:20 AMCraig1 says:
hardware store
Mar 31, 2009. 10:09 PMwax54 says:
up or down which one will i see
Apr 8, 2009. 4:12 AMjam906 says:
I used a glue gun, it worked fine.
Dec 18, 2006. 6:04 PMImpendingdoom says:
How did the light shine through? Legos arent translucent.
Jan 28, 2009. 3:19 PMCapt. Fat says:
Ding Dong
Jan 16, 2009. 5:52 AMcornflaker says:
Put a piece of paper between you and a light, last time I checked paper isn't translucent either :P
Jan 12, 2009. 7:03 AMdarkbro999 says:
actually, some of the newer ones that they have come out with are translucent, well, to a point. not exactly "clear" persay but they will let some light through.
Mar 23, 2009. 3:00 PMfwjs28 says:
WOW! that sounded smart!
Jun 16, 2008. 7:07 PMzoozie says:
hey, i have a question. i dont know much about computers and when i stuck mty flash into that and was about to glue it it looked like there were andawful lot of parts that could get messed up by regualr craft glue or "Krazy Glue" i dont know and cant get and *clear silicone" whatever that is and since im making a practice one w/ a broken flash im gonna go ahead and glue it. hopefully this will be answered tomorow. thx for the help in advance -zoozie
Jun 17, 2008. 12:11 AMDerin says:
no conductance=no problem
and clear silicone is also called silicone caulk
Dec 6, 2008. 6:15 AMJamnog says:
try an aquatics shop clear silicone glue is used for repairing fish tanks.
Apr 1, 2007. 11:20 AMpowerfool says:
The LED is on the other side that is not visible now, right??
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:ianhampton
