Remove these ads by
Signing UpStep 1Get your stuff
Yes, I know. You've probably seen this before, and your probably saying that this wasn't my idea. So no, its not my idea. I just couldn't find it on instructables, so I decided to post it as a reference for the rest of us.
You will need:
A USB memory stick (the thinner the better, it should be thinner than the lego piece)
Some Legos (either 2x4, 2x8, or whatever size you need to fit the memory stick.
A dremel, with a sanding part and that spinner-disc thingy part (see picture)
Hot glue
great guide btw:)
one last thing MEGABLOCKS SUCK
If you use plumbing goop it takes 48hours to fully harden but holds like crazy. Then if you use some small super magnets (rare earth) and insert them in to the inside of the lego casing while the glue dries; you get a cap that holds itself on.
I attached the pic with dimes simply to show the magnet placements. Also I would suggest you make a template or use slow speed on the dremel to avoid making a bumpy line on your holes.
