3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lego USB memory stick
Step 3Fit the USB and glue it in.
Once you've cleared out the insides of the lego piece, slide in your USB stick. If needed, thin the walls of the Lego from the inside to allow for more room.
To glue the stick in, first put some dabs of hot glue on the inside of the Lego. Then, carefully position the memory stick on top. Once you feel that you've got the position right, glue the sides of the USB to the walls of the Lego piece. If your memory stick as a small light on it, remember to point it downwards, so the light can shine through the glue.
Now, completely cover all the circuits with glue, as to protect the memory stick from wear and tear etc etc....
2 comments
Aug 6, 2009. 9:28 AMtaljurf says:
wont the glue affect the usb?
Apr 4, 2010. 2:25 PMbassclarinet23 says:
Surprisingly no.
May 22, 2011. 8:43 AMLaffyDuck187 says:
Not too surprising... Hot glue is an insulator. Try covering up one end of a battery with hot glue, then hook up 2 wires and a flashlight bulb. It won't work. The only thing you should worry about is the hot glue burning the circuit board or overheating it.
Jun 29, 2011. 6:13 PMbassclarinet23 says:
Yeah, I was worried that the heat would mess it up or something, but it turned out okay.
Jan 3, 2012. 10:56 AMM0HIZ says:
As long as you only apply heat for a short amount of time (no more than about 4 seconds continuously), the board and components should be fine. After all, some soldering irons work at 400 degrees centigrade but they don't damage the circuitry.
Sep 10, 2009. 4:16 PM2=2 says:
No. I've done like 4 of these. The glue doesn't affect it in the slightest.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:padfoot447
