Introduction: Lego Usb Memory
Hey, today im am going to show you how to build a lego usb memory. This is my first instructabel. Sorry for the bad pictures i used my ipod touch. Sorry for my bad English. English is not my first language.
Step 1: Materials
Materials: Usb memory (i used a two gig one) Lego brick Lego plate Tools: Hot glue gun Screwdriver Dremel Sandpaper
Step 2: Preparing Usb Memory
Start of by removing the case from your usb memory. I used a screwdriver. Then you want to find a lego brick and a plate in the right size.
Step 3: Preparing the Lego Brick
Now you want to use your dremel with a sanding tool and remove everything inside your lego brick. Use your dremel to cut a hole where the usb memory will stick out. Sand it with sandpaper. Make sure that the usb memory will fit inside your lego brick.
Step 4: Finished
The last thing you want to do is to glue usb memory inside the brick. Then take your lego plate and glue it to the bottom.
