Introduction: Lego Viking Ship
This is an example of one of the many lego projects I have completed. I really like this one a lot!
Step 1: Materials
(48)x brown 2x4 (bricks)
(2)x brown 4x12 (plate)
(2)x brown 4x8 (plate)
(1)x brown 1x12 (plate)
(1)x brown 1x8 (plate)
(4)x brown 1x2 (plate)
(1)x blue Lego base plate
(2)x brown 1x2 (plate with one stud in middle)
(2)x brown 1x6 (bricks)
(4)x brown 1x4 (bricks)
(6)x brown slanted 2x2 (bricks)
(2)x brown slanted 2x3 (bricks)
(2)x brown arch (brick)
(24)x brown 2x2 (brick)
(2)x brown 2x3 (plate)
(2)x black little connector pipes
(1)x Black ship pole
(36)x Red 2x2 (bricks)
(27)x White 2x2 (bricks)
(2)x Dark gray 1x14 "with holes in it" (brick)
(1)x brown 1x3 (plate)
(1)x Brown 1x1 plate.
Step 2: Putting Bottom Together
Take 1 4x12 plate and 1 4x8 plate and place them together then what you want to do is get 8 brown 2x4 brick and 4 brown 2x2 bricks. Along the right side attach 2 2x4 brick across the 4x12 plate and 4x8 plate. Next put 1 2x2 brick beside the 2 2x4 bricks. Next put 1 2x4 brick beside the 2x2 brick. Next put a 2x2 brick is side the 2x4 brick. Then put another 2x4 brick at the end. Next do the same to the other side. Next do what you just did but on the top right of each of the bricks (both sides). Continue the process 3x on each side. After that take another brown 4x12 plate another brown 4x8 plate a 2x12 and a 2x8 then attach them to the bricks that are 2ed to the bottom like in picture.
Step 3: Putting the Front of the Boat Together
Take 1 brown 2x3 plate then add 2 brown 1x2 plates be side the 2x3. Once you have done that add 1 brown 2x4 brick on top of the other plates once you have done that take 3 brown 2x2 bricks and put them on top of the 2x4 bricks. Then add 2 brown 2x4 bricks on top of the 3 2x2 bricks. After take 1 2x2 bricks and 2 2x4 and add them to the top of the 2 2x4 bricks. Next you will 1 slanted 2x3 brick and add a slanted 2x2 brick on top front part of the brick. Next you want to add another slanted brown 2x2 brick on top front part of the other slanted brown 2x2 brick repeat the process once more. Next place brown 2x4 brick on top back of the brown slanted 2x3 brick. Next put 1 brown 1x4 brick on top back of the first brown slanted 2x2 brick. Then add 3 brown 2x2 bricks on top of the brown 2x4 brick. Then add 1 brown 1x4 brick on the top back of the second brown slanted 2x2 brick. Next add 1 brown 1x6 brick on top of the brown 1x4 brick. Next add 2 brown 2x4 brick on top of the 3 2x2 bricks. Next add 1 brown 1x2 that has only 1 stud in the middle and place that on the top front part of the 4th brown slanted 2x2 brick. Next add 1 brown Lego arch brick to the brown 1x2 with one stud. Next add 1 brown 1x3 plate to the top of the brown Lego arch. Next add a 1x1 plate to the 1x3 plate. Next add that piece to the other peace you have made like in the picture
Step 4: Putting Back of the Boat Together
Step 5: Putting the Sail Together
First you get 1 dark gray 1x14 brick with "holes in it". Next get the 9 red 2x2 and you start stacking them on the dark gray 1x14 "with holes in it" like in the picture. After you finish that take 9 white 2x2 and do the same thing. Continue this pattern until you get to the end of the dark gray 1x14 brick "with holes in it". Next add another dark gray 1x14 brick with "holes in it", above the 9th 2x2s like in picture. Next insert 1 little black tub into the middle hole of both dark gray 1x14 brick "with holes in it". Next attach the whole sail to the black pillar like in picture then attach the black ship pole then to the boat.
Step 6: Finishing Touches
First put the base of the boat in the middle of the base plate. Then add the front of the boat in front of the base of the boat. Then add the back of the boat to the back of the base of the boat.
