Lego ship USB stick
 by NondoX
Featured
This has been done loads of times so far, but who cares? Not me I love playing with Lego,
I carry around in my laptop bag a USB micro SD card adapter and the case has fallen off and it is getting damaged and I decided today to make an enclosure/case for it.
So I popped round to my local Hackspace ( HSNotts ) and spent half hour rummaging around to see what i could use/adapt/butcher for my case and I found a tub of LEGO, and so here we are and this is what I did.
Things we need:
  • Lots and lots and lots ( or just enough! ) Lego
  • A donor USB stick, mine was a micro sd card adapter with a 4gig card.
  • Superglue
  • Imagination.
  • Blue Tac / plastercine ect
How we do it.
  1. Get your donor USB stick and strip the existing case off so all you have is the inner workings
  2. Grab your pot of Lego and just build till you get something you like.
  3. But don`t forget we need a way to fix the stick so it stays in place when we are using it so use some bluetac top and bottom inside your Lego case.
  4. Double check it fits in a USB socket and works!
  5. Carefully take it apart remembering what goes where and carefully glue all the bits together. In my case as it was an adapter I still needed to get to the innards if I was to change the Micro SD card so I didnt glue it around the middle. ( you`ll see in the photos.)
  6. HAVE LOTS OF FUN, AND TRY A FEW DIFFERENT IDEAS.
  7. Take pictures and post them all over the internets.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
