3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Lens Aperture Exploded in Resin
  • last photo ←
I travelled to New York the last Christmas and I enjoyed it as much as troubles me and my family had there. One of them was my sister's camera.  It lens got blocked; maybe because of the high changes of temperature (We live in Canary Islands, so we aren't used to control those things). The thing is that we couldn't take photos there with that camera. Now, I decided to take the piece that wasn't working (aperture) and sink it into resin, making a gift for my sister in order to remind her the good (and bad) times we had in New York.
This 'ible is an example of what can you do with transparent resin, so the following instructions can be taken for other ideas. The resin used is Transparent Polyester. I bought it on this store , very cheap by the way.
Step 1Safety First
Safety First
Resin can become an hazardous issue if you don't take the correspondent precautions. There are required some protections:
- Latex or nitrile gloves.
- A Mask for the fumes
- Acetone (is the best product for clean polyester resin).
43 comments
1-40 of 43next »
Sep 22, 2011. 11:34 AMeyrops says:
I like to undercatalyze polyester resin to reduce the exotherm, and reduce the risk of cracking. That increases the setting time, of course. I also often use styrene monomer as a "float layer" to wet the object so bubbles don't stick to it. I then pour the catalyzed resin into the liquid monomer layer. Looks like your project turned out very well without those precautions, but they might help someone doing a thicker project or one with a surface more likely to trap air.
Sep 24, 2011. 8:25 AMeyrops says:
I don't know for sure. I'm not very familiar with polyvinyl alcohol I thought it was used as a mold release, so my guess is that if you painted it on and let it dry, it might separate the object from the resin. That would probably not be what you want. The thing about styrene monomer is that it wets the surface and is compatible with the resin as the resin cures. So, for example, if you have a complicated porous object such as a dry piece of bark, you can anchor it with a thin resin layer. Then you can pour a layer of styrene monomer over it. It will wet the bark. Then you can pour the next layer of resin right into the monomer, and continue. Styrene monomer is available from Industrial Arts Supply Company in Minnesota.. I haven't looked into other sources.
Mar 1, 2012. 10:16 PMtinker234 says:
wow amazing i wonder if i could do something like this with a old camera i have on my shelf
Feb 21, 2012. 9:43 AMcekpi7 says:
is good to put a small speaker inside and drill holes so i can hear it??
Sep 22, 2011. 4:47 PMBubbler says:
I have a snake skull that I always wanted to put into a cube or or ball shape. The bones of the jaws and teeth are extremely fine, so is this the stuff I would use for that please? Do I need to make it less viscious?
Oct 20, 2011. 9:24 AMavatar_i says:
Oh, man, is that a great idea, or what!!!
I have several small animal skulls that I collected in the deep woods, and I always thought a nice display would be cool, but I coudln't figure out how!
Thanks, Plugable, thanks, Bubbler, you ROCK!
Sep 24, 2011. 4:03 PMBubbler says:
Thanks Plugable, your information is just what I required.
Sep 26, 2011. 9:11 AMmathieulj says:
To avoid bubbles, you could experiment with different solvents mixed in with the resin. I don't know the specific solvent/resin that was used but someone I know was casting optics and solved her bubble problem by doing so. It would increase cure time but it's higher liquidity would allow the bubbles to rise to the surface.
Sep 26, 2011. 8:44 PMNarlo11 says:
Styrene momomer is a thinner used about 2-5% to thin resin.
Sep 24, 2011. 2:29 PMNoitoen says:
After the first sanding, if you give a few thin coats of transparent acrylic varnish it will become crystal clear.
Sep 22, 2011. 9:26 PMtrojan52 says:
The silvery thingies you are talking about are probably caused by a thin layer of air trapped beetween the resin and the lens.
You might want to take a look at the url at the bottom of my comment, it's a wikipedia entry about the phenomenom (total internal reflection).
http://en.wikipedia.org/wiki/Total_internal_reflection
Sep 22, 2011. 6:32 PMnerd12 says:
do you know any where i can buy the resin in India?
pls reply
the site was also in Spanish or something which i did not understand.
Sep 22, 2011. 3:45 PMguaps says:
Do you think this would work for insects too? I found a huge cockroach in my room while visiting a friend in Venezuela. I want to put it in some resin like this.
Sep 22, 2011. 12:38 PMomgitschrislol says:
Would it make a better cast if I were to use one of those clear plastic boxes from walmart? They have perfect angles and all that and wont leak. Even come with a lid to make the bottom section seperate. I am OCD when it comes to perfect angles and stuff so this would be a must. The only issue i can think of would be sticking but i think you can use Pam cooking spray or the like.
Sep 22, 2011. 10:13 AMmurraykaynottawa says:
That is a really niffty idea.
And I think your sister would be thrilled to receive such a great piece that you obviously worked hard to prepare for her !
Great job !!
Sep 22, 2011. 10:04 AMdestroyer2012 says:
If you don't want to invest in polish paste or a special cloth for this purpose, I have had good success with toothpaste and a sock.
Sep 22, 2011. 8:30 AMdrdasd says:
Very cool project that can be applied to most anything that has parts! Also great for using stuff that would otherwise be thrown away. Thanks for sharing!
Would the resin found here work for this? http://www.tapplastics.com/shop/product.php?pid=37&
There is a local store so it would me much more convenient for me!
Sep 22, 2011. 9:54 AMihart says:
Great idea to display a lens like that. I would just use epoxy resin. There is no 4 hour sanding effort. It dries perfectly clear.
You spray mold release into your mold. Next, mix the resin and hardener exactly in a 50/50 ratio for each layer you are making.
Here is an example of the epoxy resin/hardener:
http://www.amazon.com/Environmental-Technology-16-Ounce-Casting-Craft/dp/B000GBT8V0
Here is an example of mold release:
http://www.amazon.com/Environmental-Technology-4-Ounce-Release-Conditioner/dp/B000XAWQJU/ref=pd_sim_ol1
Sep 22, 2011. 9:22 PMtrojan52 says:
Sure you could use epoxy resin, but your project would probably be 10 fold more expensive.
Sep 22, 2011. 12:40 PMcoldblackice says:
Great idea! Thanks
Sep 22, 2011. 5:38 PMchuckyd says:
The surface still looks fuzzy. You could get a smoother finish if you sanded up to 12,000 grit paper, and then polish with 3-step auto polish.
The grits above 1,000 were developed for cleaning airplane windows.
Sep 22, 2011. 12:44 PMomgitschrislol says:
Could you use a vacume eleminate air bubles? If i were to put that in a sealed case while the Acrylic was hardening and i applied a vacumme would it pull the bubbles out? I absoluty love stuff like this. Im going to be going to college to be an electrical engineer.
Sorry for spelling and gramatical errors I reciently cut the crap out of my thumb on a cd drive case and am typing without it and its actually harder than i thougt.
Sep 19, 2011. 7:09 PMWasagi says:
This is beautiful!! Great job!
Sep 18, 2011. 11:55 PMlemonie says:
The shiny bits will be air layers, yes.
Maybe wetting the parts with un-activated resin first would fix that?
L
Sep 19, 2011. 12:26 AMfrank26080115 says:
I remember learning about how to make crystal clear ice, the trick was to apply some air pressure , would that help in this case?
Sep 19, 2011. 11:04 AMlemonie says:
Negative air pressure, but that's degassing, the air in this block wasn't in the liquid. And resin is more viscous than water.
L
Sep 19, 2011. 8:32 AMtheweldingwizard says:
On the site you posted to buy the resin ,waz it 1 kilogram for 10$ ,i wanna make a clear counter top, and can't find any store's in Montreal that have it a a resonable price,and if it is can the ship to Canada???
Sep 18, 2011. 6:49 PMfrank26080115 says:
Would a soda can make a good cylindrical mold?
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:plugable
I'm a physics student. I like to build stuff and learn about electronics.
