Lens Making
2,736
51
Published
Introduction: Lens Making
About: I am a Franco-American Designer and Artist. I earned my undergraduate degree at the Ecole Superieur d' Art et de Design of Reims , where I majored in Product and Spacial Design. I went on to receive my Mast...
Learn how to make fun optics:
Lenses are fascinating both the process of making and the wild distorsions they create are a great skill to learn.
Glasses, telescopes, microscopes, kaleidoscopes... are all lenses.
With these steps you will learn tricks on how to make concave lenses in a cold working glass shop.
Step 1: CHECK YOUR GLASS
Make sure there aren't any cracks in your glass piece. If you have a polarized lens you can use it to check on cracks. Otherwise simply looking at every surface before starting works too.
Step 2: MARKING
Use a sharpie marker to trace the location where you'd like your lenses to be. It's always best to draw a circle slightly smaller inside to avoid carving the outside cercle.
In order to stay perfectly circle use a sharpie to mark the cercle. The water and friction will take the sharpie off after a while so it's absolutely normal if you spend more time marking then carving at first.
After lots of practice your eye will get more and more trained and you will be able to carve a circle without using as many marks.
Step 3: GRINDING
In a coldworking glass studio you will be able to grind your sheet of glass.
Clothing: Wear a mask, apron, and plastic boots because the silica+ water will get all over as your grinding the glass.
Place the water in order for it to drip on the glass to avoid thermal shock.
Since the grinding wheel has a rounded profile it will carve the glass with a round outer shape. It takes a lot of time and practice to do a perfect cercle. Marking the glass with some extra space will be important incase the outside of the cercle gets scratched.
Movement: When you are pushing the glass onto the wheel make sure you are not pushing too hard since the wheel does the job simply bringing it gently close to the wheel with a firm grip will suffice. Sometimes you can do very minimal horizontal and vertical movements but the more you are still the more the round will be carved evenly without any bumps.
Step 4: TRANSLUCENT TO TRANSPARENT
As you can see on the attached picture the area that has been carved is cloudy and the untouched area is transparent. Here is the key to a perfect transparent lens with no translucent " cloud" and no scratches:
Similar to wood and metal glass can overheat. Make sure you are cooling the glass with the water drip and not staying on the wheel too long. It's always good to take breaks and feel the glass incase it got too warm.
Start with the roughest diamond grit wheel to the finest one to get a perfect glass shine.
Order of carving lenses with a spherical diamond grit wheel:
80- 150- 180- 320- 600 - felt wheel
Once you are satisfied with the look of your lens and the finish it has. You can go to the felt wheel shining area to improve the shine.
Use a mix of pumice and water added to the felt wheel to create a fabulous shine.
VOILA
Step 5: ENJOY
You can apply this technique to any glass surface.
Also you can integrate the lens with another part like into a camera.
By adding more lenses on both sides of the glass you will end up with really cool patterns and shadows.
Light and optics are magical, I hope you will enjoy the great process of making lenses and exploring light and vision with them.
Pictures attached show an exploration of hydroponics with lenses and some 6 facets lenses I made.
Please reach out with any questions you may have I'm happy to help you out.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Microcontroller Contest
    3 Comments
    Aww....would love to do this, but there's no coldworking glass studio around....
    Very cool. I had never thought about making my own lenses before. But I might have to try this out.
    Thanks!I hope you will it's so fun to do!!
