The design was developed and tested by Ed Lenz of Windstuffnow.com:
http://www.windstuffnow.com/main/lenz2_turbine.htm
The Lenz2 VAWT (Vertical Axix Wind Turbine) is 4 foot tall and 3 feet in diameter. It is a basically a Savonius style turbine but with the refinement that the three wings are shaped to provide lift as well because or their teardrop configuration. In the above link Lenz describes how he placed an ananometer inside the stational turbine and showed that the windspeed picked up passing past the solid portion of the wings. This turbine is more efficient than a pure Savonius in that it provided both drag and lift.
In my design I scaled down the diameter to approximately 18 inches and the height to 21 inches. (In hindsight, I should have made the height 18 inches so that there would be more of the center axis free on both ends for flexibility in mounting.)
I was able to use materials I had on hand to build the turbine. When I tested it in a 15 mph wind, it worked so well that I was afraid to stop it for fear of getting injured. The only downside of what I produced is that it seemed to produce very little electricity. This is not due to the design of the turbine but to the nature of the DC motor that I had it attached to. The emphasis in this tutorial will be on how to construct the turbine itself. Full credit for the design and some of the instructions goes to Ed Lenz.
[Note: Since this instructable was published, I learned more about how the wings should be shaped. The construction details for the lenz2 provided in this instructable still hold but the dimensions of the wing in Step 2 should be substituted for those given in the newly inserted Step 3.]
Remove these ads by
Signing UpStep 1Materials needed
Materials
Plywood (quarter or half inch)
Steel strapping with holes in it (other alternatives are possible)
Nuts and bolts
24 inch allthread rod (half inch diameter)
.5 inch nuts that fit on the althread rod (about 6 of them)
Roof flashing, thin sheet metal, or even some sort of flexible plastic
9 pieces of lumber, .5" x 1" x 18"
Hardware for mounting your turbine (you will have to design this)
Tools
Drill and drill bits
Tin snips
Jigsaw
Wrenches
1/2.618034 = .3819661, 1 - 0.3819661 = 0.618034
I would think the rationale behind this is that the Golden Mean has very interesting self-referential and scale invariant properties. Since air is essentially scale invariant macroscopically at low wind speeds, I would expect the self-referential nature of the Golden Mean to produce a high probability of self-reinforcing aerodynamic behavior. (1/1.618034 = 0.618034, 1.618034^2 = 2.618034, 1/2.618034 = 0.381966 = 1 - 1.618034, etc.)
This both controls optimizes efficiency speed and offers a relatively loss-less way to control speed. Other advantages are simplicity and the resulting low cost,
...should have read:
This both optimizes efficiency and offers a relatively loss-less way to control speed.
I can put wind on either side of my VAWT and it will spin in the same direction. The lift pulls it forward on the side moving into the wind, although very slowly. That's better than simply neutral and way better than just less drag on the side moving into the wind as in the Savonius. There is much stronger lift that pulls it toward the side moving with the wind even before it gets to 90 degrees to the wind. Then it takes off like a rocket and pours wind into the next blade forward as well. The wind through the turbine wraps way around the back side so you can channel a fan into the most productive side and feel the wind coming out about two thirds around from a normal to the front facing the wind.
So lift is a big deal and potentially increases efficiency a lot over a straight Savonius or drag-based turbine. Other huge advantages, besides not having to swivel windward to maximize power, combine to favor VAWTs. Examples are no gears and the potential for magnetic levitation (maglev) and the lower losses to friction that brings.
Maglev can simply be a bi-product of a generator built right into the turbine. Ideally the coils and magnets should be placed just inside the outer edge where the maximum speed exists. The stator can use speaker magnets (very powerful ones available). The coils can pass over the statro magents underneath or potentially even through C-shaped magnets placed on the outside of the bottom rotor rim. You can even wire the coils so at low speeds you use only half or a third of the coils (evenly spaced) and cut the others in as wind speed increases. This can be built into a control system and optimized for the specific power versus wind speed curve of a particular design implementation. This both controls optimizes efficiency speed and offers a relatively loss-less way to control speed. Other advantages are simplicity and the resulting low cost,
http://en.wikipedia.org/wiki/Darrieus_wind_turbine#Cycloturbines
Add plastic bushings for easier rotation, and consider an upper frame to hold the top bearing end of the center axle rigid, so the energy lost in the wobble at speed is regained. (such a frame will be outside the circle through which the wings move. It ought not to affect the wind to the rotor assembly.)
If the circumference is 20ft., then the shaft speed will be only 1/2 revolution per second.
It will however have more torque, because the arms will be longer.
The http://www.instructables.com/id/Wind-turbine-with-bicycle-wheels/
instructable gave me some ideas but it will require using both wheels for support. It also has the advantage of fixed gears on one of the wheels. That could be used to an advantage for getting higher RPM.
Also that turbine looks like it would go twice as fast if the shaft were not so wobbly.
Can you provide the cad drawings?
I want to have it laser cut
