Step 11Mount the turbine to the generator
The motor has plus and minus spade connectors at one end and a shaft protruding from the other end. Unfortunately the shaft was half inch in diameter with fine thread. This makes it very difficult to mate with something like an allthread bar with is half inch coarse thread.
The way I solved the problem is to bolt an L-shaped bracket to the shaft of the motor. Then I used a piece of metal that I had saved from an old tiller. It is U-shaped and has holes on the side and a threaded hole on the top. The threading is half inch coarse thread, just perfect for mounting the allthread bar. Finally, bolted the U-shaped connector to the L-bracket.
I cut a hole in a piece of plywood large enough to insert the motor. After inserting the motor to the plywood, I bolted it down. To try out the turbine, I placed the whole affair on top of a heavy wooden box.
comment
Add Comment
Add Comment
